Multiswitch component, one button multiple outputs
- ArcEye
- Thank you received: 240
This component just demonstrates a one button toggling switch as discussed in this thread.
Can be expanded for more outputs if required.
www.linuxcnc.org/index.php/english/compo...10&id=10272&start=12
(see post 15809 for updated version)
- BigJohnT
- Thank you received: 994
That is pretty neat! Should that comp be added to master?
- Rick G
- Thank you received: 114
Cool, I will have to try that, I am running out of buttons on my joypad.
Rick G
- Thank you received: 4647
Can we make it take a modparam for number of outputs?
Give me an hour, I will make a version which does it that way for evaluation.
- ArcEye
I have tested in simulation, setting the pins with halcmd and verifying it cycles and sets flags as it should.
It could do with a real world trial, if Rick is thinking of trying it, I can wait for any feedback first.
I will also wait to see what Andy comes up with, don't know if it is worth a modparam argv / argc type interface when there is only one settable param, but it would make it easier to use and more consistent with other components interfaces I suppose.
Updated version of my offering with toggle set back to input here
[Give me an hour.
Make that three. I got distracted.
The only real advantage to doing it this way is that it supports up to 32 output bits.
It probably needs to support "names=" to be well-behaved component.
EMC2 HAL component to implement Multistate toggle switch
(c) ArcEye 15122011 schooner30@tiscali.co.uk
example Hal linkages required:-
loadrt multiswitch cfg=4,6,8
addf multiswitch.0 servo-thread
net toggle-switch multiswitch.0.toggle <= parport.N.pin-nn-out
net state1 multiswitch.0.state1 => parport.N.pin-nn-in
net state1 multiswitch.0.state2 => parport.N.pin-nn-in
net state1 multiswitch.0.state3 => parport.N.pin-nn-in
If you require an "all off" state, then make the component one bit oversize and
don't connect the extra pin.
component multiswitch """This component toggles between a specified number of output bits""";
pin in bit up = false "Receives signal to toggle up";
pin in bit down = false "Receives signal to toggle down";
param rw unsigned top-position "Number of positions";
param rw signed position "Current state (may be set in the HAL)";
pin out bit bit-##[32:personality] = false "Output bits";
modparam dummy cfg """cfg should be a comma-separated list of sizes
for example cfg=2,4,6 would create 3 instances of 2, 4 and 6 bits respectively.
Ignore the "personality" parameter, that is auto-generated""";
function _ ;
option extra_setup yes;
option count_function yes;
variable int old_up = 0;
variable int old_down = 0;
author "ArcEye schooner30@tiscali.co.uk";
license "GPL";
#define MAX_COUNT 32
int cfg[MAX_COUNT];
RTAPI_MP_ARRAY_INT(cfg, MAX_COUNT, "array of function sizes");
FUNCTION(_) {
int i;
// debounce
if (up && !old_up) { position++; }
if (down && !old_down) { position--;}
old_up = up;
old_down = down;
if (position < 0) position = top_position;
if (position > top_position) position = 0;
for (i = 0 ; i < personality; i++){
bit(i) = (i == position);
EXTRA_SETUP(){
personality = cfg[extra_arg];
top_position = personality - 1;
return 0;
int get_count(void){
int i;
for (i=0; cfg[i] != 0 && i < MAX_COUNT; i++){}
if (i == 0){
cfg[0] = 4;
i = 1;
return i;
}Please Log in or Create an account to join the conversation.
- ArcEye
Personalities and modparams are not something I have played with yet in .comp programming.
The components I have written have been either, only intended for use as singletons, or I have manually set params etc.
It didn't make complete sense until I expanded the macros and generated a C file.
You polish it and publish as your own, there is nothing in there of mine, save the concept, which is hardly unique.
Indeed. I am using at least two undocumented features there.
It is a pity that there is no way to omit "personality" from the auto-generated docs in cases where you are not using it (actually, it would also be nice to be able to alias "personality" to a modparam name of your choosing.
- fabworx
- Rick G
For example
loadrt or2 count=2
loads 2 or2 components.
Some good reading...
linuxcnc.org/docs/2.4/HAL_User_Manual.pdf
Rick G
