Multiswitch component, one button multiple outputs
- ArcEye
- Thank you received: 240
20 Dec 2011 08:15 #15883
by ArcEye
Replied by ArcEye on topic Re:Multiswitch component, one button multiple outputs
Hi
Just to clarify, multiswitch is a custom component, just recently written, may or may not make it into a distribution.
To use it you need to download it from the link, compile and install it.
or2 and dozens of other components ARE part of the emc distribution, a full list of them linked to descriptions is here.
www.linuxcnc.org/docview/html/hal_components.html
You already have the compiled module in /usr/realtime-2.6.32-122-rtai/modules/emc2/or2.ko, you just need to to load and connect it in your .hal file, in accordance with whatever you are using it for.
- fabworx
20 Dec 2011 09:31 #15890
by fabworx
Replied by fabworx on topic Re:Multiswitch component, one button multiple outputs
Or2 docs I have but I didn't have the or2.lo in the right folder and couldn't find it in my folders I found it on the git source tree and compiled it thanx you guys
