hal-core
- AlessandroT
- Thank you received: 4
06 Dec 2021 08:46 - 06 Dec 2021 08:54 #228426
by AlessandroT
Replied by AlessandroT on topic hal-core
Last edit: 06 Dec 2021 08:54 by AlessandroT.
07 Dec 2021 08:55 #228510
by Grotius
If you give me the company link, i will contact you.
P.s. is this your github account? github.com/alessandrotorre
We want to test it in a multipurpose application
I am still making progress every day. Some parts of the code take a lot off time.
It can be used offline and online. This makes testing easyer.
What kind of multi purpose application are you thinking about? If you have any 3d drawings of the application, i can add it to the config like i did previously for a fanuc tig weld app. If your config is closed source then you can use the software as it is.
My motivation is learn how to write software and write free software for the linux community.
- AlessandroT
07 Dec 2021 09:04 #228512
by AlessandroT
Thanks Grotius for the reply.
Yes I started with linuxcnc and 3D printing long time ago and I'm very thankful for the existence of this community that is really crazy and amazing!
Our company name is "rev3rd".. If you google it you can find us. I think your motivation is completely in line with our philosophy.
If we could have a videocall i will explain you more and maybe if we could make progress, share the progress for everybody here.
The pourpose is the hybrid manufacturing:
Printing and milling!
- AlessandroT
07 Dec 2021 09:31 - 07 Dec 2021 09:44 #228517
by AlessandroT
thanks, but the email is not received...
Last edit: 07 Dec 2021 09:44 by AlessandroT.
15 Dec 2021 21:06 #229163
by Grotius
A tiny hal-core update.
Working on the trajectory planner for day's now.
I had problem's with the ruckig s-curve motion planner when using end-velocity's. That's solved now.
In general coding the trajectory planner with a s-curve is a difficult job. Things like adative-feed, velocity-overide, controlled stop, velocity transition etc have to be coded. Then on top we have a path optimizer to calculate the perfect velocity's from the gcode file, this replaces a look ahead function.
Hopely i can show a new video within a few day's to show the progress.
Bye bye !
Bye bye !
15 Dec 2021 21:41 #229167
by Dave3891
Hi Grotius,
Looks like you are making great progress on this project, I am really impressed with how fast your are going.
I am looking at the code (V1.20) and I had some questions about how everything is interacting with each other.
Is it correct that the flow from motor to control would go like this:
Stepper Motor -> HalStepgen -> HalKinematic -> HalTrajectory -> GUI
If I wanted to make a really simple GUI to jog a 6 axis robot in a XYZ plane with no 3D visual feedback and only DRO, would I just send commands to the HalTrajectory component?
Also I am not really familiar with the euler parameters, but I see you are using it a lot with axis and jogging. Would you be able to explain what that is?
Sorry for all the questions, I just want to get a full grasp of the system before I start trying it out.
16 Dec 2021 09:19 #229182
by Grotius
To jog a robot without a gui and just using the kinematics, you could look at this project.
It will work by using halcmd to jog. Using a graphical interface would be easyer for debugging.
The workflow you suggested is correct. Looking at the ./runtest file's will give you the tested workflow.
The euler angles is the 3d rotation of the toolposition or last joint position of the machine or robot kinematic chain.
It is the same as jaw,pitch,roll but then defined as euler xyz.
Euler xyz is for me easyer to use then jaw,pitch,roll because in the graphics you can directly see by the colored axis origin on wich axis the
tool will rotate. Then related to lcnc, there are no euler xyz gode names. For the euler xyz we use the gcode a,b,c letters.
So a 3d gcode in hal-core will look like : G1 X0 Y0 Z0 A0 B0 C0 U100 F1400 S100 M300 P45 M301 P11
how to perform motion. .
If you look at my current work, /opt/hal-core/src/hal/components/matrix, this is a all in one component. Currently in development stage.
It has benefits like using dynamic memory in c. Correct memory release for opencascade when closing drawings.
Fail safe double[4][4] rotation-translation matrixes connection between kinematics and graphics for each joint.
It has improved algo's, but still working on it every day. The graphics are just amazing. I hope the result of the trajectory planner will be
amazing to.
If you have any questions or problems, just ask.
- g1 (lineair movment)
- xyz (toolcenterrpoint tcp).
- abc (euler xyz toolposittion in degrees).
- u (can be a gripper or exernal axis position).
- f (feedrate).
- s (spindlespeed).
- m (macro).
- p (marco value of type double, for example set output 300 to value 45).
amazing to.
17 Dec 2021 03:00 #229263
by Dave3891
Hi Grotius,
Thank you for the explanation, it makes a lot more sense now.
Looking at that example, am I right in assuming that velocity and acceleration and speed are either handled with the stepgen module or by feeding in small chunks of movements to the kinematics module?
I did not see any speed/velocity pins in the kinematics module so I am assuming that it takes the XYZ request and gives the J0-J5 end positions instantly?
Sorry for all the questions.
20 Dec 2021 16:19 #229557
by Grotius
Hi Dave,
Yes, stepgen handles that in the example.
Yes, the kinematics only calculates the positions visa versa.
For hal-core i am busy with the scurve library for several day's now.
The ruckig scurve lib has some problems:
under the hood.
So i started for the third time coding my scurve lib.
Now hoping to get everything ok within a few day's. I think i make a flag so lineair transition can be added in the
scurve between the concave and convex period. This makes the machine even faster as a normal scurve.
A period of lineair transition is all the time "2* max acceleration".
The picture shows the front curve, using a concave and convex period.
The curve can do a acceleration start value, and a acceleration end value.
I am coding it as stand alone c/c++ compatible library.
- In a realtime 1ms kernel powered thread bringing back the current velocity to 0.001 will crash at longer paths.
- End velocity accuracy out of control when crossing waypoints.
- When end velocity can not be reached, ruckig end velocity value is 0 instead of value at end of path.
under the hood.
Time to create page: 0.139 seconds
