hal-core
01 Nov 2021 21:12 #224917
by Grotius
Hi Dave,
You can try to do a new hal-core install. Eventually rename your existing hal-core dir to save current data.
github.com/grotius-cnc/hal-core/tree/mai...mponents/opencascade
For his example, you can edit the hal file to your robot datasheet. hal file example
Then in the ./runtest you can see how your stepfiles are loaded. runtest example
You can add your fanuc stepfile's in the same context as the other 2 robot examples.
Then in the video's you can see how to move the robot by halcommands. Most of time you would set
a hal_kinematic pin to move the robot in a certain position. When hal_kinematic pins are connected to a motion controller,
the robot will follow the path.
01 Nov 2021 21:15 #224918
by Grotius
- Thank you received: 5961
01 Nov 2021 22:39 #224927
It has to be moderated to change the title in all existing posts.
Replied by tommylight on topic hal-core
To what would you like to rename it?rename topic test.
01 Nov 2021 22:56 #224929
by Dave3891
Thanks Grotius, I will give it a try tomorrow.
Does the opencascade hal module also do the robot kinematics or just the simulation?
Can I connect the opencascade output to the hostmot2 stepgens? Or is there something needed in between?
Hi Dave,
02 Nov 2021 03:29 #224946
by Grotius
Hi Tom,
If you could rename it to "hal-core" would be nice. Thank you!
Hi Dave,
They are seperated. Connected to each other by hal commands. "./runtest" files give a example how they are connected.
1. user input values to kinematics.
2. kinematics result to opencascade inputs.
As long as it is a "hal out pin" you can connect it to a stepgen. The hostmot2 is available. I never used it, but you can connect it.
If you take this example : github.com/grotius-cnc/hal-core/tree/mai...omponents/trajectory
Do the ./runtest and have a look. Jogging works, also loading a gcode works with motion planner.
To preview the gcode, you have to load the gcode file a second time in the opencascade app, sorry for that.
Your connection to the hostmot2 stepgen would be something like :
net signalname_j0 hal_kinematic.pin_j0 hostmot2.etc..
net signalname_j1 hal_kinematic.pin_j1 hostmot2.etc..
net signalname_j2 hal_kinematic.pin_j2 hostmot2.etc..
I just compiled the hal-core from source and above example worked right away. So now everyone can try it within minutes.
Hi Dave,
02 Nov 2021 03:36 - 02 Nov 2021 04:38 #224947
by Grotius
When you did the new install, in your desktop menu there is a new program, "halview" this can show your hal configuration.
Another way to preview hal pin names is to : $ /opt/hal-core/bin/./halcmd show
Also the program cam is in your menu entry. This can make a nice gcode from a dxf drawing.
When you have your robot files configured okey, i can add them to the repository with the datasheet. It would be nice
to colorize the stepfiles a bit. It takes some time but it's worth it.
Your robot stepfile's and datasheet are uploaded over here !
A runtest for the fanuc was not working after my first attempt. I have to stop for today.
I see the stepfile positions differs from the kuka example. It seems the fanuc have to be rotated 180 degrees?
Can you compare the kuka stepfile positions with your fanuc stepfile positions. I think when this is done, we are a step further.
For the datasheet, some joint min and max value's are not defined. I guessed them for now.
Oke. good luck !~!
Oke. good luck !~!
Last edit: 02 Nov 2021 04:38 by Grotius.
02 Nov 2021 10:15 #224970
Done.
Thank you.
Thank you.
02 Nov 2021 17:39 #225021
by Dave3891
Thanks Grotius!
That looks awesome, I am setting up a fresh debian 11 VM to test out the install from scratch right now.
Again, thank you for all the help
Time to create page: 0.153 seconds
