Led linked to the state of a Physical pin???
23 Dec 2014 07:03 #54240
by mmt
Led linked to the state of a Physical pin??? was created by mmt
I am new to Glade. I have everything working as I would like except the leds.
Can someone show me an example of the code to put in me post-gui.hal file.
Ex. I want led_1 to show the state of parport 1 pin 2 (true-led_1 on....false-led_1 off)
23 Dec 2014 09:43 - 23 Dec 2014 09:48 #54243
Replied by cmorley on topic Led linked to the state of a Physical pin???
It depends on if the parport pin has a signal connected to it already.
Assuming it doesn't:
net led1_signal parport.1.pin-02-in led_1
Last edit: 23 Dec 2014 09:48 by cmorley. Reason: didnt notice it was parport 1
The following user(s) said Thank You: mmt
23 Dec 2014 09:45 #54244
The name of the led will probably actually be gladevcp.led_1 but check to be sure
23 Dec 2014 11:33 #54249
by mmt
Replied by mmt on topic Led linked to the state of a Physical pin???
Thank You that worked perfect
One other question
How do I activate a Led based on the fixture offsett
Ex. I want to have labels G54 G55 G56 etc with led next to each one so that when the offset is active the led is on?
Thanks again
kent
One other question
Thanks again
kent
23 Dec 2014 14:09 #54253
There is no easy way to do it.
it would require python programming called from the glade panel
Chris M
Chris M
30 Dec 2014 01:50 #54372
by mmt
Thanks for your help Chris.
I do have one problem though. I don't have the physical pin in my main hal file. i simply turn the pin on and off with a M code.
When I add
net led1_signal parport.1.pin-02-in hal_led1
to my custom_postgui.hal file my M code will not function. i.e. change the state of the pin?
When I add
30 Dec 2014 05:48 #54389
Well the quoted line actually connects the parport pin (driving pin) to the led (driven pin)
It's the parport pin that drives the LED.
Do you want to drive the LED by Mcode too?
Please explain what you are trying to do.
Chris M
Chris M
30 Dec 2014 13:05 - 30 Dec 2014 13:10 #54404
by mmt
Yes I would like it to come on with M101 and go off with M102 if that is possible. ??
M101 turns parport 1 pin 2 true and M102 turns parport 1 pin 2 false.
I was trying to do it with the state of the physical pin but that didn't seem to work the way I am doing it.
Last edit: 30 Dec 2014 13:10 by mmt. Reason: added
06 Jan 2015 01:39 #54596
The previous example linked the LED to the state of an _input_ parport pin.
If you want the LED state to echo the status of an _out_ parport pin, then one way to do this is to have HAL:
net theled gladevcp.led_1 parport.0.pin-01-out (or some pin that is an actual output)
Then the M101 bash script can be
halcmd sets theled 1
This sets the -signal- value to 1, and that forces both the LED and the parport pin to 1.
Replied by andypugh on topic Led linked to the state of a Physical pin???
06 Jan 2015 02:12 - 06 Jan 2015 02:16 #54602
by mmt
Thanks Andy but I have tried that and still cant get it to work.
I will attach my files here if you could look at them for me.
M Codes are in the next post
Last edit: 06 Jan 2015 02:16 by mmt.
Time to create page: 0.205 seconds
