Led linked to the state of a Physical pin???
06 Jan 2015 02:13 #54603
by mmt
Replied by mmt on topic Led linked to the state of a Physical pin???
Here are my M code files
06 Jan 2015 02:15 #54604
Replied by andypugh on topic Led linked to the state of a Physical pin???
What do the M-codes look like?
You won't be able to "sets" a signal linked to a HAL output pin (note that physical parport input pins are output pins to HAL)
06 Jan 2015 02:19 #54605
by mmt
I can't get them to post
here are the contents
M101
# Laser Beam Enable
halcmd sets beam-on 1
exit 0
M102
# Laser Beam Disable
halcmd sets beam-on 0
exit 0
M101
# Laser Beam Enable
exit 0
M102
exit 0
06 Jan 2015 03:10 #54608
I think the problem will be that the hal-checkbutton instantly over-rides the sets commandIf you want to be able to operate it from both a checkbutton _and_ a G-code then things get more complicated.
net beam-on gladevcp.hal_checkbutton1 gladevcp.hal_led1
The following user(s) said Thank You: mmt
07 Jan 2015 04:59 - 07 Jan 2015 05:05 #54693
by mmt
Andy thank you for your help.
I swithched from the check button to 2 buttons ( on and off ) using a hal mdi command to activate the m code with an led and used your suggestion
"net theled gladevcp.led_1 parport.0.pin-01-out (or some pin that is an actual output)
Then the M101 bash script can be
halcmd sets theled 1"
I works perfect now. Thanks again
Last edit: 07 Jan 2015 05:05 by mmt.
10 Jan 2015 00:54 #54829
by mmt
OK I jumped the gun by saying that it works perfect.
When I hit the run button on a program, Glade grays out my M code buttons and my leds and the M codes will not function from the program.
what do I need to add and where? Something to my postgui. hal file?
10 Jan 2015 01:49 #54832
Ah, yes. That is a problem.
The buttons to call the M-codes are "MDI" buttons and are not active in "Auto" mode. (ie, when a program is running).
This actually makes some sense, as there can only really be one source of G-code instructions active at any one time.
This is going to seem over-complicated, but I suggest that you link the M-code value, some GUI buttons and the halui.mode-is-auto pin through a LUT5 component. Then you can set up the output to do whatever it is that you really want to happen in each mode.
(LUT5 allows you to specify the state of an outpbut bit for every possible combination of up to 5 input bits, like an arbitray 5-input logic gate)
10 Jan 2015 01:55 #54833
by mmt
Thank you again Andy. It worked.
10 Jan 2015 01:59 #54834
Crikey! That was quick, I was mentally braced for a week of explaining LUT5
Time to create page: 0.145 seconds
