CamView for Wheesy and Jessie
30 Mar 2017 17:16 #90583
by mmt
Replied by mmt on topic CamView for Wheezy and Jessie Revisited
I get this error on step 3 when I run sudo python CamPY_setup.py
I am running Wheezy with 2.7.8 installed
File "CamPY_setup.py", line 24, in <module>
cache = apt.Cache()
File "/usr/lib/python2.7/dist-packages/apt/cache.py", line 102, in __init__
self.open(progress)
File "/usr/lib/python2.7/dist-packages/apt/cache.py", line 149, in open
self._list.read_main_list()
SystemError: E:Malformed line 7 in source list /etc/apt/sources.list (dist parse)
cache = apt.Cache()
self.open(progress)
31 Mar 2017 09:43 #90629
by ikkuh
This is not a clue to you?
Replied by ikkuh on topic CamView for Wheezy and Jessie Revisited
31 Mar 2017 15:19 #90651
by mmt
No I'm sorry but it is not.
01 Apr 2017 16:16 #90713
by newbynobi
Replied by newbynobi on topic CamView for Wheezy and Jessie Revisited
Please post you sources.list, there will be a strange line in it.
Norbert
Norbert
18 Apr 2017 05:33 - 18 Apr 2017 05:40 #91567
by jrsphoto
Replied by jrsphoto on topic CamView for Wheesy and Jessie
Just an fyi, I think I found a bug between this module and the buildbot linuxcnc 2.8.0-pre1 with the latest gmoccapy. I've posted the error here:
forum.linuxcnc.org/gmoccapy/26314-gmocca...cnc?start=1300#91566
I've noticed that if I remove just hal_pythonplugin.py from /usr/lib/pymodules/python2.7/gladevcp, linuxcnc then starts but camview does not load.
Cheers
Cheers
Last edit: 18 Apr 2017 05:40 by jrsphoto.
21 Apr 2017 07:01 #91751
by newbynobi
Replied by newbynobi on topic CamView for Wheesy and Jessie
Hallo John,
during my discription and your install, the filed you mentioned has changed, that causes the error. Have you tried boggies install script?
Install Script for Campy
Norbert
Norbert
22 Apr 2017 00:12 #91826
by jrsphoto
Awesome, thanks Norbert, I'll give the script a try tonight
06 May 2017 23:38 #92760
by bogie6040
Replied by bogie6040 on topic CamView for Wheezy and Jessie Revisited
Thanks, glad you found it useful, I wasn't sure if the subroutines for moving the machine would work for most however it seemed to work on my machine at work. I will try to finish the wiki page I started a while ago some time soon.
07 May 2017 12:26 #92769
by Tchefter
Replied by Tchefter on topic CamView for Wheezy and Jessie Revisited
Works straight out of the Box, that means, Installation 1:1 from the perfect Read.me and it works.
Many thanks!!!!
Many thanks!!!!
17 Aug 2017 00:01 #97601
by blazini36
Replied by blazini36 on topic CamView for Wheezy and Jessie Revisited
I'm working on a project that is based almost entirely around the camera which I made a glade GUI for. Since I know very little about programming and Gstreamer 1.0 seems to be incompatible with GTK2 I can't get anything other than this camview widget to work. Basically I just need a big videobox in my GUI. The V4l2 controls are great, but I'd rather have them in the mainwindow of my GUI
Right now I'm trying to pull the buttons, circles, and text out of it but any modifications I make to the python file make it angry.
Also the video stream is paused any time a "run" command is issued. I assume this is for performance but jog commands are not effected. Is there any way to have this not be the case?
Time to create page: 0.917 seconds
