CamView for Wheesy and Jessie
19 Nov 2018 09:02 #120981
by Gene1934
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page <geneslinuxbox.net:6309/gene>
Replied by Gene1934 on topic CamView for Wheesy and Jessie
If udev is doing its job, the camera should be detected when plugged back it, but due to an incomplete cleanup when it came unplugged, the path to it might change. In that event, whats in memory would be wrong as to where it is, and LCNC may need to be restarted to find it again. Its possible some hints to the udev bugzilla might help in the long run if enough folks ask about a fix. I think that's my situation also, or at least the first thing I'd check. Write down the path from the boot log, and compare that to what dmesg shows when the device has been plugged back in.
Best I can deduce from here.
Cheers, gene1934
Cheers, gene1934
19 Nov 2018 11:39 #120985
by blazini36
Replied by blazini36 on topic CamView for Wheesy and Jessie
I think it's more likely that camview (or it's backend) isn't releasing the camera's resources. The kernels device names are usually pretty good until you add a second video device, then you start to have problems with the naming order, if video1 is pulled it will become video3 if there is a video2 in existence. In that case writing hardware based UDEV rules has solved the issues with my project so I don't rely on kernel naming. I still have an issue with the cameras resources if it were to be unplugged while running but that's generally not a huge deal for me.
19 Nov 2018 20:47 - 19 Nov 2018 20:47 #121020
by newbynobi
Replied by newbynobi on topic CamView for Wheesy and Jessie
Imho it is not a matter of udev. I think the python class looses the connection to the videodevice.
Have you tested what happen if you stop the capture using the camview button before unplugging the cam? And plug in the cam, wait a few seconds and restart capturing?
Otherwise you will need to edit the python file and add a feature to unconnect the videodevice before unplugging.
Norbert
Norbert
Last edit: 19 Nov 2018 20:47 by newbynobi.
20 Nov 2018 00:56 #121033
by Gene1934
I hadn't considered that, Norbert, mainly because my problems aren't related to a sudden disconnect from a sloppy usb socket, but to switch from shrink to expand and back, right st the cameras native size (800x600) as the axis screen is resized.
I remounted the camera today, looks good. But I'm mid rebuild of the box being driven by the P2 connector ATM. Using a Sainsmart bob, and real psu's, but am seriously looking at a mesa 7i76 to run it all, I'm essentially out of i/o, and considering making a tool changer and possibly a pallet holder too.
Thanks Norbert.
Cheers, gene1934
Thanks Norbert.
Cheers, gene1934
20 Nov 2018 15:01 #121061
Gene: You happily download LinuxCNC from this site, that includes low level kernel drivers and an OS that take total control of your hardware.
Making life difficult for yourself and everyone else by refusing to download files from the forum makes no sense.
It is your decision to make, of course, but it is unreasonable to expect us to compensate for your paranoia.
Replied by andypugh on topic CamView for Wheesy and Jessie
This is true, but to get that info it has to query the forum driver, which will then reply with anything including an attack vector
- Thank you received: 5944
20 Nov 2018 15:52 #121065
Wow, how did i miss this ???
I was a network security expert for 2 of the biggest organisations on earth ( UN and OSCE, they still use windows, i do not like windows ), and this is my advise : Know what you are talking about! Forum driver ??????
I would suggest reading all my posts, but that would take to long and the posts that did have security issues are removed already. Getting off topic...
@Gene, read more
@Andy, thank you for putting it so eloquently.
Replied by tommylight on topic CamView for Wheesy and Jessie
@Gene, read more
20 Nov 2018 16:04 #121066
by Gene1934
The fact is that since the button image wasn't titled, or even looked like a clickable button, was a far bigger impediment as it never occurred to me to hover over it to see if it did have something to say. Now that I know, it won't happen again.
Thanks Andy
Thanks Andy
06 Dec 2018 02:25 #121917
by Nitram
Replied by Nitram on topic CamView for Wheesy and Jessie
Occasionally after some use, I get unusual behavior, specifically Gmoccapy freezing.
I have attached the error log following the event. Contained within are ongoing references to:
1:
select timeout
and 2:
libv4l2: error dequeuing buf: No such device
VIDIOC_DQBUF: No such device
with the second reference reoccurring a huge number of times in the debug section of the log.
The libv4l2 reference infers a camera issue??
Without being majorly Linux savvy, is the camera overflowing a buffer here and causing a crash??
I also notice the camera itself getting quite warm (I suspect from resistors to run the LED lights it has in the tip), is it possible this represents the camera ultimately overheating and going offline, resulting in the system not finding the camera anymore and resulting in a buffer overflow/crash?
If this is the case, per a previous post, it would be handy to be able to set up the usb camera as a hot pluggable device and thus to only use it for the time necessary.
Debug section of the file attached.
Thanks,
Marty.
1:
select timeout
and 2:
Thanks,
Marty.
06 Dec 2018 07:32 #121929
by Gene1934
i don't know as this i the exact same problem I have when resizing the camera image, which causes the camera tab to turn white/blank, and needs a LCNC restart to fix. But it could be from a similar cause. I'm using axis which throws another variable into the witches pot and don't seem to be getting your extensive debug log but I don't have debug tracing enabled in axis,
ATM I can't test the rest of it under load, a $2.50 buck voltage regulator failed shorted, putting 35 volts into a 5 volt BoB so I'm in the middle of rebuilding the whole LCNC interface box which will give me another 48 i/o points, badly needed, but I'm also in the middle of getting my cataracts fixed so am not seeing well enough for fine machining for mounting the plug/sockets and soldering that will be needed to bring it back to life. So the best I can do is confirm there is a problem needing some TLC for 100% dependability. But I'm not a python or glade expert either. I've done mosdt of my gui work with pyvcp, which is both a screen real estate hog and bulletproof.
Cheers all, Gene1934
07 Dec 2018 10:25 #121998
by newbynobi
@Marty
Norbert
Norbert
Time to create page: 0.179 seconds
