Glade 3.8.5 and LinuxCNC RIP build: how to install the catalog?
06 Dec 2016 19:08 - 06 Dec 2016 19:10 #83719 by islander261
Hello
I just want to report that I finally got all the HAL widgets to work with my Glade 3.8.5 install. In addition to doing this:
You need to copy all files from
linuxcnc-dev/lib/python/gladevcp
to
/usr/lib/pymodules/python2.7/gladevcp
and
/usr/share/pyshared/gladevcp
I also needed to do this:
sudo cp ~/linuxcnc-dev/lib/python/gladevcp/*.xml usr/local/share/glade3/catalogs
As well as:
[sudo cp ~/linuxcnc-dev/lib/python/gladevcp/*.png usr/local/share/glade3/pixmaps
I still can't start Glade from the terminal with the glade-gtk2 command but glade-3 works for now.
Last edit: 06 Dec 2016 19:10 by islander261. Reason: fix formating
The following user(s) said Thank You: kpj10
05 May 2018 03:54 #110231 by kpj10
Add the LinuxCNC stuff to the GLADE_CATALOG_SEARCH_PATH: export GLADE_CATALOG_SEARCH_PATH=~/linuxcnc-dev/lib/python/gladevcp
I didn't get where to put this. I'm using Ubuntu 14.04, simulation installation.
I tried writing this in my /etc/environment file but still there is catalogue not found error.
Hope for your help,
Thank you
Kunal.
09 May 2018 10:14 #110414 by thang
Kunal.
Just do this command in terminal :
Moderators: HansU
Time to create page: 0.669 seconds
