Vismach in Gscreen/GladeVCP
- mlhilligsoe
25 Nov 2019 13:27 #151217
by mlhilligsoe
Vismach in Gscreen/GladeVCP was created by mlhilligsoe
Hi, I'm running Gscreen and would like to implement a window that shows the machine. Basically Vismach.
As far as I can find, the same question has been asked here:
sourceforge.net/p/emc/mailman/message/28934796/
and here:
forum.linuxcnc.org/48-gladevcp/34664-is-...ismach-into-gladevcp
But they dont specify how to actually do this. Can anyone guide me on how I can implement a Vismach window in gui?
Or is there a better way of doing this? e.g. some way of showing 3D objects in the gremlin widget?
and here:
26 Nov 2019 21:40 #151317
by newbynobi
Replied by newbynobi on topic Vismach in Gscreen/GladeVCP
Just use embedded tab for your purpose.
You can use gmoccapy documents to get first information about how to do it.
Norbert
Norbert
26 Nov 2019 22:19 #151321
Replied by cmorley on topic Vismach in Gscreen/GladeVCP
Vismach does not currently pass the XWindow Id when it starts so can't be embeded the normal way.
I forget how I temporarily worked around this for a test but probably got the ID number from the system monitor program and used it instead of the {XID} entry.
I never did get back to modifing the code to work a little more user friendly.
You might make a feature request so I don;t foget again - I am currently to busy to look at it.
Chris
Chris
Time to create page: 0.164 seconds
