- Thank you received: 11
is it possible to embed vismach into gladevcp?
8 years 4 months ago #111519
by thang
is it possible to embed vismach into gladevcp? was created by thang
I wonder if Vismach can be embedded into gladevcp like gremlins?
8 years 4 months ago #111619
Replied by andypugh on topic is it possible to embed vismach into gladevcp?
You might be able ti embed it as a standalone tab. But Gremlin is a special widget, rather than a generic thing that is embedded.
So I imagine you would need a version of this file, but importing Vismach rather than Gremlin.
github.com/LinuxCNC/linuxcnc/blob/master...devcp/hal_gremlin.py
The following user(s) said Thank You: thang
8 years 4 months ago #111627
Replied by cmorley on topic is it possible to embed vismach into gladevcp?
With a small change to have vismach export the X window id then it should be embeddable.
I'll look at it when I get time.
Chris M
Chris M
6 years 6 months ago #164809
by thang
Replied by thang on topic is it possible to embed vismach into gladevcp?
Hey Chris, did you find out the way to export the X window id from vismach module?
6 years 6 months ago #164875
I did not find away to have this vismach export X id. It seems tkinker doesn't support that.
I then started trying to convert to Qt and..got side tracked
I'm sorry - I'll try to get back to it - I do want the capability in Qtvcp too.
Chris
Chris
5 years 10 months ago #192308
Moderators: HansU
Time to create page: 1.000 seconds
