Upgraded from 2.7 to 2.8 and GladeVCP is not working
- LearningLinuxCNC
- Topic Author
- Thank you received: 61
02 Jun 2023 21:41 #272768
by LearningLinuxCNC
So my SSD failed on my mill. I was able to recover the data from the main partition but the boot partition was not working.
I copied my configuration data and did a new install of 2.8.4 from the latest stable release.
Put my configuration files in and started it up. All is working except for my custom GladeVCP.
I had probe screen loaded in the past configuration. If I have it loading I get the following error.
If I comment out the probe screen and only load my two custom GladeVCP panels I get the following error.
What is different between 2.7 and 2.8 that would be causing this?
(gmoccapy:3197): GtkSourceView-CRITICAL **: 16:40:00.870: gtk_source_language_manager_set_search_path: assertion 'lm->priv->ids == NULL' failed
RB1-CNC_PostGUI.hal:22: Pin 'SBOGladeCB4.TBSpindleBrakeOverride' does not exist
File "/usr/bin/gladevcp", line 41, in <module>
import gtk
File "/usr/lib/python2.7/dist-packages/gtk-2.0/gtk/__init__.py", line 44, in <module>
from gtk._lazyutils import LazyNamespace, LazyModule
KeyboardInterrupt
File "/usr/bin/gladevcp", line 46, in <module>
import gladevcp.makepins
File "/usr/lib/python2.7/dist-packages/gladevcp/__init__.py", line 1, in <module>
from hal_pythonplugin import *
File "/usr/lib/python2.7/dist-packages/gladevcp/hal_pythonplugin.py", line 18, in <module>
from state_label import State_Label
File "/usr/lib/python2.7/dist-packages/gladevcp/state_label.py", line 16, in <module>
import gobject
KeyboardInterrupt
3138
/usr/bin/gladevcp:191: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
builder.add_from_file(xmlname)
3193
Stopping realtime threads
Unloading hal components
File "/usr/bin/gladevcp", line 347, in <module>
main()
File "/usr/bin/gladevcp", line 248, in main
window = xembed.reparent(window, opts.parent)
File "/usr/lib/python2.7/dist-packages/gladevcp/xembed.py", line 13, in reparent
from Xlib import display
File "/usr/lib/python2.7/dist-packages/Xlib/display.py", line 38, in <module>
from .xobject import resource
File "/usr/lib/python2.7/dist-packages/Xlib/xobject/resource.py", line 22, in <module>
from Xlib.protocol import request
KeyboardInterrupt
PPMC: shutting down
Note: Using POSIX realtime
(gmoccapy:2731): GtkSourceView-CRITICAL **: 16:32:18.303: gtk_source_language_manager_set_search_path: assertion 'lm->priv->ids == NULL' failed
File "/usr/lib/python2.7/dist-packages/gladevcp/hal_pythonplugin.py", line 1, in <module>
from hal_widgets import HAL_HideTable
File "/usr/lib/python2.7/dist-packages/gladevcp/hal_widgets.py", line 16, in <module>
import gobject
KeyboardInterrupt
import gtk
File "/usr/lib/python2.7/dist-packages/gtk-2.0/gtk/__init__.py", line 40, in <module>
from gtk import _gtk
File "/usr/lib/python2.7/dist-packages/cairo/__init__.py", line 1, in <module>
from ._cairo import * # noqa: F401,F403
KeyboardInterrupt
2672
2727
PPMC: shutting down
- Thank you received: 5949
02 Jun 2023 21:51 #272769
Replied by tommylight on topic Upgraded from 2.7 to 2.8 and GladeVCP is not working
From both of your logs:
- LearningLinuxCNC
- Topic Author
02 Jun 2023 22:08 #272771
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Upgraded from 2.7 to 2.8 and GladeVCP is not working
I see this. Why did it exist and now it does not?
- LearningLinuxCNC
- Topic Author
02 Jun 2023 22:12 #272772
by LearningLinuxCNC
Just to clarify SBOGladeCB4.TBSpindleOverride is the pin for a HAL Toggle Button on my Glade VCP panel. Did something change with HAL Toggle Buttons between 2.7 and 2.8 that would cause this issue. All of the files within my config folder are the same. Has to be something outside the main config. I don't recall changing any code for the HAL Toggle Button in the previous version. However my memory could be failing me here.
- LearningLinuxCNC
- Topic Author
02 Jun 2023 22:15 #272774
by LearningLinuxCNC
If this helps any my remaps are not working either. If I try to run M6 in MDI it sets there and does nothing. I have to stop the MDI command mannualy but the machine does nothing.
02 Jun 2023 22:16 #272775
No idea, never used glade that i am aware of.
I would first check if glade is installed or grown or whatever it needs to be for it to be used by LinuxCNC.
sorry for the vague reply.
hmmmm
glade uses UI files or something like that, check if those files are present.
hmmmm
- LearningLinuxCNC
- Topic Author
02 Jun 2023 23:12 #272781
by LearningLinuxCNC
The ui files are present and they show up fine if I comment out the postgui.hal file that tries to connect to the pin.
I guess my question is why is the pin not there.
Glade is installed. The docs say to have glade-gtk3 3.8.0 or lower it is 3.8.6-1 is what is installed.
python-gtk3 is installed 2.24.0-5.1
Linuxcnc was installed from the installer so it should be configured as installed according to the docs.
03 Jun 2023 00:41 #272785
Another stab in the dark, but do those UI files have to be executable to work?
Copying stuff in Linux tend to remove the executable flag.
- LearningLinuxCNC
- Topic Author
03 Jun 2023 00:52 #272788
by LearningLinuxCNC
Not sure if they need to be executable or not. I think the problem is with this part of the error message.
I don't think it is finding gladevcp.makepins. I could be wrong but seems like it could be the cause.
gladevcp_makepins.py existis on the computer however it says it is depreciated and to use gladevcp.makepins.
I will do another test tomorrow but for now I am done for the day. Worked on it from about 5:00 to 7:00 with no progress so I am tired out.
03 Jun 2023 07:15 #272799
by HansU
Replied by HansU on topic Upgraded from 2.7 to 2.8 and GladeVCP is not working
It would help if you could post your configuration and your Glade file.
Time to create page: 0.170 seconds
