Upgraded from 2.7 to 2.8 and GladeVCP is not working
- LearningLinuxCNC
- Topic Author
- Thank you received: 61
03 Jun 2023 13:03 #272817
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Upgraded from 2.7 to 2.8 and GladeVCP is not working
OK,
So I commented out the PostguiHAL lines that were attempting to connect to the missing pins. Launched Linuxcnc and took a look at HALshow to see what was going on.
Attached iis a screenshot showing that the pin in question does exist. It is only being netted in the postgui-hal file, Also attached. For reference you can also see my ,ini file attached.
Very puzzling.
Very puzzling.
- LearningLinuxCNC
- Topic Author
03 Jun 2023 13:23 - 03 Jun 2023 13:27 #272819
by LearningLinuxCNC
Furthermore. If run the netting commands connecting to the button copying and pasting the commented lines from the PostGUIhal file It works.
Un-comment the lines in the PostGUIhal file and it gives the error.
Last edit: 03 Jun 2023 13:27 by LearningLinuxCNC.
- LearningLinuxCNC
- Topic Author
03 Jun 2023 13:38 #272820
by LearningLinuxCNC
Seems a similar issue was raised on this thread.
forum.linuxcnc.org/gmoccapy/47803-custom...-cannot-load-postgui
According to one post the display calls the postgui.hal file, Gmoccapy is being used in both cases so something must have happened between 2.7 and 2.8 that causes Gmoccapy to call postgui.hal before the GladeVCP panels are fully loaded.
03 Jun 2023 17:04 #272822
by HansU
What if you connect the pins in SBOHalCB4.hal instead of in the postgui hal file?
Replied by HansU on topic Upgraded from 2.7 to 2.8 and GladeVCP is not working
The following user(s) said Thank You: LearningLinuxCNC
- LearningLinuxCNC
- Topic Author
03 Jun 2023 20:27 #272837
by LearningLinuxCNC
That was the fix.
Thank you sir.
Thank you sir.
04 Jun 2023 11:02 #272872
by HansU
Time to create page: 0.188 seconds
