First Configuration try-Dead Machine
24 Feb 2012 19:34 #18043
by ohioflyer
Replied by ohioflyer on topic Re:First Configuration try-Dead Machine
Please forgive me, I am trying to grasp the flow of signal input to signal output to drive output, I think I have not assimilated the terminology enough to be fluent and properly express myself, as well as comprehend your helpful ideas. I wave wired my machine precicely as this diagram shows, which is direct from Kelings website. With the exception of course that the steppers are wired for bipolar parallel, and then connected to the wires from the drivers. Because I have checked and double checked my wiring I feel It must be a jumper problem, or something I am doing wrong with the software. I will try re-enabling the the E-stops as well, I checked thier continuity and they are properly NC
24 Feb 2012 19:36 - 24 Feb 2012 21:00 #18044
by cncbasher
Replied by cncbasher on topic Re:First Configuration try-Dead Machine
com should be set on the bob for +5v
( com jumper pins 2 -3 on the bob )
and then connect C10 to the pulse + and dir + connections as this
pin 2 (x axis step) is connected to step pulse -
pin 3 ( x axis dir ) is connected to dir -
on the stepper driver
and you will need to have the EN pin connected to 5v also
as this internaly enables the output of the bob only ( wire jumper is fine here )
leave the stepper drive enable opto's totaly disconnected
they are not needed for operation , and can be optional in use
later down the line
the C10 is a product of cnc4pc.com
so much information is also available there
later down the line
Last edit: 24 Feb 2012 21:00 by cncbasher.
24 Feb 2012 19:39 #18045
by ohioflyer
Yes, My PS supplies 36 VDC to the drivers. I am not seing the PM option, I would be glad to...
24 Feb 2012 19:47 #18046
by cncbasher
ohioflyer wrote:
click on ,my name and a mail box should pop up
24 Feb 2012 19:52 - 24 Feb 2012 20:48 #18047
by cncbasher
email me
Last edit: 24 Feb 2012 20:48 by cncbasher.
24 Feb 2012 20:00 #18048
by ohioflyer
no sorry, only your profile, the only communication option there is to send an email, I'll look some more, mybe I'm just blind
24 Feb 2012 20:34 #18049
by cncbasher
seems inface that the pm and email side of the forum is broken or disabled
25 Feb 2012 14:14 #18078
by BigJohnT
Replied by BigJohnT on topic Re:First Configuration try-Dead Machine
You have to click on Messages > Send E-mail after going to the profile.
26 Feb 2012 00:51 #18088
by ohioflyer
so, CNCbasher has helped me quite a bit. Unfortunetly our timezones are pretty far apart. I believe we have the problem narrowed down to communication between computer and bob. Are there any instances where linuxcnc2.5 will not send pulse signals?
26 Feb 2012 08:51 #18090
by cncbasher
thats usual down to a broken kernel , especialy if you have allowed ubuntu to update any part of the kernel , although you are resonably ok updating programs .
the other is of course a broken parallell port .
and make sure your parallell port cable is 25 pins wired 1 :1 and not one of the cheaper cables as they do not always have all the wires
also it's easy if making your own cables to cross the wires when making the plugs
start with a clean install from the cd and do not run update to start with
check the logs for any signs of something not running
run dmesg from a terminal and see if it mentions any rtai errors , if so this usualy means the kernel is damaged
Time to create page: 0.233 seconds
