First Configuration try-Dead Machine
26 Feb 2012 09:28 #18091
by Rick G
Replied by Rick G on topic Re:First Configuration try-Dead Machine
Not sure where you are in troubleshooting but you might find a clue here...
www.linuxcnc.org/index.php/english/compo...ew&catid=50&id=17142
wiki.linuxcnc.org/cgi-bin/wiki.pl?TroubleShooting
wiki.linuxcnc.org/cgi-bin/wiki.pl?Parallel_Port_Tester
Rick G
Rick G
03 Mar 2012 18:54 #18324
by ohioflyer
Replied by ohioflyer on topic Re:First Configuration try-Dead Machine
So I checked my cable and all of the pins appear to be 1:1. I found not rtai errors, I'm on a clean install with the new ppa. I have done no updates. I checked the troubleshooting guide and it mentioned adding a line to the hal file, but when I checked the line was already present. The machine is still dead.
04 Mar 2012 11:13 #18335
by cncbasher
Replied by cncbasher on topic Re:First Configuration try-Dead Machine
post your current hal file and ini file , and i'll take a look
04 Mar 2012 12:10 #18337
by Rick G
Have you checked to see if you do in fact have an output from EMC at the driver board?
If you test a direction pin from one of the axis it should change from around 5 volts one direction to 0 in the other direction with EMC running.
This would show that EMC is running properly, you have the correct parallel port address, the parallel port is configured and working in the proper mode, with the proper voltage and that the cable is good.
Rick G
Rick G
22 Mar 2012 04:25 #18702
by pfred1
Replied by pfred1 on topic Re:First Configuration try-Dead Machine
I'm old school so I have an oscilloscope for when I run into signaling questions. LinuxCNC has something called HALscope that might give you more information about what is going on? Someone else on the board is going to have to help you there though. I've only heard of HALscope, I haven't had the pleasure of ever using it.
I know with my motor drivers I had to set a pulse width in order for them to work right. Too small a width and they didn't run. But keep at it, the stuff does work:
Time to create page: 0.114 seconds
