Work with probe
- sarcokiller
26 Jan 2018 00:03 #105023
by sarcokiller
Replied by sarcokiller on topic Work with probe
Hi all, I installed the probe screen and I have all the probing routine working. By the way it seems that if I check the box "Auto Zero" the code is actually zeroing my absolute coordinates and not the relatives! So I can't start a job after probing because of course my new machine coordinates will be the piece coordinates and I got the error that I'm exceeding the axis limits.
Any suggestions on how to fix this?
26 Jan 2018 11:35 #105032
by Mech john
Replied by Mech john on topic Work with probe
did you set G43 after loading your probe? i am using the auto zero function and it works fine..
cheers!
cheers!
- sarcokiller
26 Jan 2018 16:14 #105045
by sarcokiller
Hi, no I'm not using G43.
This is what I do:
- power on the machine and homing the axis and zero G54 coordinate system
- jog the axis over the stock that I would to use
- Hit the "Probe Down" button
- Hit the insidde circle "Hole button" and zero XY in the hole of my probe that correspond to an angle of the stock
- now I could be in the position to start the job, but see how looks the coordinates in my preview screen:
and I got the limits error of course
Here's how the coordinates look if I jog manually over the corner of the piece and I hit "Touch Off"
now I can start the work but of course it's not too precise cause I didn't use the probe
Other INFO:
LinuxCNC 2.7.11
what am I doing wrong?
This is what I do:
Warning: Spoiler!
<a href="ibb.co/gsbf3b">preview.ibb.co/eK07ib/20180126_170628.jpg" alt="20180126_170628" border="0">
Warning: Spoiler!
<a href="ibb.co/n1VZUG">preview.ibb.co/kMC3Ob/20180126_170839.jpg" alt="20180126_170839" border="0">
Other INFO:
LinuxCNC 2.7.11
26 Jan 2018 16:20 #105046
by Mech john
is this the first time you have tried to use your probe? do you have the probe tool offset set up? g43 loads your tool offset.. i cant say anything about your images as I only see half of them..
- sarcokiller
26 Jan 2018 16:23 #105047
by sarcokiller
My first time using my probe in LinuxCNC. In the photo you can see that with the probe my workpiece zero is over the table in a position in which the machine can't work.
04 Feb 2018 11:47 #105394
by Vitkus
Replied by Vitkus on topic Work with probe
Hello, I recently installed this application, but when I push probe down button get error message
(Error: EOF in file:/usr/share/axis/images/axis.ngc seeking o-word: o<down> from line: 0).
Maybe somebody facing similar problem and could explain what could be wrong?
29 Apr 2018 13:04 #109798
by Hendrik
I have the same issue (linuxcnc stretch build)
Replied by Hendrik on topic Work with probe
29 Apr 2018 13:29 #109801
by Hendrik
forgot to set my subroutine_path in my ini.
github.com/verser-git/probe_screen/issues/2 for more informations.
- Mike_Eitel
- Thank you received: 185
10 May 2018 13:44 #110511
by Mike_Eitel
Replied by Mike_Eitel on topic Work with probe
Hi
If I try to use probing ( on my testbench ) any of the icons axes move accordingly to symbol but when i signal a probe contact by hw-switch i get an error message with movements stop:
5:17:20 Error: Tastspitze bei inaktivem MDI-Befehl ausgelöst.
I'd translate to: probe signal when inactive MDI command...
Tried that with all modes: manual/auto/mdi
I'm on latest master / gmoccapy/ stretch
All working fine, also tool measurement in gmoccapy reacts correct on probe signal.
thx Mike
thx Mike
24 May 2018 19:00 - 24 May 2018 19:21 #111094
by javelin
Replied by javelin on topic Work with probe
I have 1 issue.
I get an error when the probe makes contact with the plate which states "probe tripped during non-probe MDI command" . I assume this is a debounce issue based upon what I have read. Have others here experienced this same issue?
Edited: Fixed the problem with probe moving the wrong direction on an axis. It was a lack of understanding on my part, as usual LOL! Also after understanding how the probe moves, upon measuring a move it seems to move 1 = 1 inch . Looking at the code it appears that the version now from github pulls in the settings from the hal and ini files if I am not mistaken. So.....
My question now is IF I have a machine setup for inches, and nother for mm it will adjust accordingly based upon the hal and ini files automatically? Please say its true LOL!
Last edit: 24 May 2018 19:21 by javelin.
Time to create page: 0.163 seconds
