Work with probe
12 Jan 2024 17:03 - 12 Jan 2024 17:05 #290511
by Mud
Replied by Mud on topic Work with probe
edit: formatting gone properly wonky, will re-post (please delete)
Last edit: 12 Jan 2024 17:05 by Mud.
12 Jan 2024 17:09 #290512
by Mud
Can anyone help with the error I'm getting? A quick sanity check of what I'm trying to do (probe_screen_v2.8 on linuxcnc 2.10) is probably worthwhile, I'm struggling to understand what's current and compatible.
I think it's related to this line:
It seems to be missing files change_prolog and change_epilog, but I don't see them in the repo .
SUBROUTINE_PATH = macros:psng/macros REMAP=M6 modalgroup=6 prolog=change_prolog ngc=psng_manual_change epilog=change_epilog
21 Apr 2024 04:40 #298756
by verser
Replied by verser on topic Work with probe
Probe Screen v2.9 update has been released:
- Designed for LinuxCNC v 2.9
- Supports Axis and Gmoccapy interfaces and screens from 1280x1024
- Supports metric and imperial
Sources
Sources
21 Apr 2024 14:45 - 22 Apr 2024 08:36 #298778
by Serg452
Replied by Serg452 on topic Work with probe
Do I understand correctly, this is just an adapted latest version 2.8? With remote disabling of tool metering?
Last edit: 22 Apr 2024 08:36 by Serg452.
22 Apr 2024 09:42 - 22 Apr 2024 09:49 #298830
by verser
Yes, this is an adapted latest version 2.8.
Probe Screen allows the tool length to be automatically measured during g-code execution when an M6 command is encountered. The user will only have to remove the old one and install the new cutter in the designated place. Remap of M6 is required in .ini. If you don't need this feature, just don't remap M6 in .iniWith remote disabling of tool metering?
Last edit: 22 Apr 2024 09:49 by verser.
22 Apr 2024 10:35 #298832
by Serg452
I did not understand the answer. I use a tool in the cone of the BT40, measure it once and then do not measure it every time. Should I change the ini file every time? Now I use a self-adapted old version with the M6 REMAP checkbox, where I turn on measurements if necessary. Why was this removed from the new version, why make the software worse?
The following user(s) said Thank You: verser
23 Apr 2024 03:36 #298888
by verser
It's clear. Thank you. I'll think about how to get the checkboxes back.
Time to create page: 0.120 seconds
