External Pause/Resume Button & Manual Tool Change
05 Dec 2015 05:43 #66438
by russtuff
External Pause/Resume Button & Manual Tool Change was created by russtuff
Right now I have an external button for pause/resume (just got it working, awesome) but when it comes to manual tool changes I still have to hit enter on the keyboard. Is there any way to have this work on the same button?
Once I get my cycle start and e-stop buttons wired up I'm going to be out of inputs on my CNC4PC BOB (my spindle and limit/home switches are the last two input pins).
My pause/resume is from this excellent post by BigJohnT: forum.linuxcnc.org/forum/47-hal-examples...tton-using-one-input
06 Dec 2015 01:20 #66490
It certainly is possible, as that is how my machine works. (it's a touchscreen so hitting "enter" was really quite hard)
There is a HAL pin created by hal_manualtoolchange that has the same effect as hitting enter or clicking the dialog.
The pin is called hal_manualtoolchange.change_button.
Replied by andypugh on topic External Pause/Resume Button & Manual Tool Change
21 May 2019 05:23 #134443
by phoenix
Replied by phoenix on topic External Pause/Resume Button & Manual Tool Change
this conf is working but i want two saprate pause and resume buttons externally
21 May 2019 06:46 #134450
by pl7i92
Replied by pl7i92 on topic External Pause/Resume Button & Manual Tool Change
then you use a OR logic
you can have many Or in ligic steps
gnipsel.com/linuxcnc/hal/or2.html
named or2 logic is a better reding
loadrt or2 or2.btn-ext-a,or2.btn-ext-b ....
addf or2.btn-ext-a servo-thread
addf or2.btn-ext-b servo-thread
net button-1 or2.btn-ext-a.in0 <= your-pin
net button-2 or2.btn-ext-a.in1 <= your-pin
net pause halui.program.pause <= or2.btn-ext-a.out
Time to create page: 0.626 seconds
