Pause/Resume Button using one input
- BigJohnT
- Thank you received: 994
29 Apr 2011 17:14 - 14 Jun 2011 11:11 #9518
by BigJohnT
Pause/Resume Button using one input was created by BigJohnT
Thanks to piasdoms constant searching I added to his example to not get out of sync if the button is pressed when not running or paused
A pause/resume button using halui and hal. The input can be either a pyvcp button or a physical button. In this example I used a pyvcp button.
xml
<button>
<halpin>"pause-resume"</halpin>
<text>"Pause/Resume"</text>
</button>
custom.hal
loadrt and2 count=2
loadrt or2 count=1
loadrt toggle count=1
loadrt toggle2nist count=1
addf and2.0 servo-thread
addf and2.1 servo-thread
addf or2.0 servo-thread
addf toggle.0 servo-thread
addf toggle2nist.0 servo-thread
postgui.hal
# External Program Pause/Resume Button
net pause-resume-btn and2.0.in0 and2.1.in0 <= pyvcp.pause-resume
net pause-on toggle2nist.0.is-on and2.0.in1 <= halui.program.is-paused
net run-on and2.1.in1 <= halui.program.is-running
net pause-sig or2.0.in0 <= and2.0.out
net resume-sig or2.0.in1 <= and2.1.out
net toggle-ok toggle.0.in <= or2.0.out
net togglesig toggle2nist.0.in <= toggle.0.out
net toggleon halui.program.pause <= toggle2nist.0.on
net toggleoff halui.program.resume <= toggle2nist.0.off
xml
<button>
</button>
custom.hal
loadrt and2 count=2
loadrt or2 count=1
postgui.hal
Last edit: 14 Jun 2011 11:11 by BigJohnT.
- piasdom
- User is blocked
19 May 2011 11:06 - 19 May 2011 11:34 #9929
by piasdom
Replied by piasdom on topic Re:Pause/Resume Button using one input
here's another example
custom.hal
loadrt toggle2nist count=3
custom_postgui.hal
#pause/resume
net pausesig pyvcp.prog-pause toggle.4.in
net togglesig toggle.4.out toggle2nist.0.in
net toggleon toggle2nist.0.on => halui.program.pause
net toggleoff toggle2nist.0.off => halui.program.resume
#net pauseison halui.program.is-paused => toggle2nist.0.is-on
xml
<button> <!-- program pause -->
<halpin>"prog-pause"</halpin>
<font>('Helvetica 2',18)</font>
<fg>"midnightblue"</fg>
</button>
Kenneth
custom.hal
custom_postgui.hal
#pause/resume
xml
</button>
Kenneth
Last edit: 19 May 2011 11:34 by piasdom.
- piasdom
- User is blocked
19 May 2011 11:53 #9932
by piasdom
BigJohnT corrected me(Thanks), it WILL get out of sync if paused without
program running.
program running.
Time to create page: 0.271 seconds
