7i77 analog out 5
15 Feb 2019 15:57 #126564
by mpvriens
Replied by mpvriens on topic 7i77 analog out 5
I have measured on a powered drive , the input measure very low resinstence.
We i put a 1.5 volt battery on the input the spindle runs fine
15 Feb 2019 16:13 #126566
Replied by PCW on topic 7i77 analog out 5
Very low?
15 Feb 2019 17:02 #126570
by mpvriens
100 ohms
15 Feb 2019 17:06 #126571
umm that cant be right...
- Thank you received: 1369
15 Feb 2019 18:02 #126575
Should be more like 100 thousand ohms.
Replied by Todd Zuercher on topic 7i77 analog out 5
100 ohms
- Thank you received: 5938
15 Feb 2019 18:23 #126577
Replied by tommylight on topic 7i77 analog out 5
That might be the other analog input meant for 0-20mA current, but it looks to low even for that.
Does the drive have another "sollvert" input? Try that one if it does.
15 Feb 2019 19:03 #126581
That does sound like a likely explanation...
20 Feb 2019 12:52 #126814
by mpvriens
Did some test on the 7i77 analog output4 : when put and resistor of 10Kohn on the output en setp to 5 volt, the output drops to 3 volt, if i put a resistor of 12kohm on the output the voltage keeps correct 5 volt
20 Feb 2019 13:29 #126815
Sure its 10K resistor?
If a 10K resistor causes an output drop, that likely means the 7I77
opamp that drives that pin or the 7I77s +-14V power suppiy is damaged
21 Feb 2019 09:23 #126853
by mpvriens
yes i'm realy sure it is a 10 K resistor
output 5 has the same issue
