Y axis has two joints and they move in opposite directions
14 Apr 2024 17:16 #298236
If you are saying that jogging one way works, and jogging the other doesn't, then that would seem to suggest that one motor moves in the same direction regardless of the DIR pin, and you probably need to check that. (You can check DIR with a multimeter)
Replied by andypugh on topic Y axis has two joints and they move in opposite directions
Is there a missing word in this sentence?[justify]when i am jogging the machine in direction it works fine but when i jog it in - direction both y axis motors moves in opposite direction [/justify]
14 Apr 2024 20:48 #298255
Replied by rodw on topic Y axis has two joints and they move in opposite directions
Some servos have a setting to reverse the default motion direction. This may need to be set on one drive.
