Y axis has two joints and they move in opposite directions
- norbertfarquharsh
18 Jun 2019 15:06 #137190
by norbertfarquharsh
I have tried to solve this problem and looked at the ,hal and .ini file and tried different things and cannot figure why in the Y axis the joints move in opposite directions.
I will also say that I cannot get homing to work properly with the HOME_IGNORE_LIMITS set to NO as they are supposed to be.
I have edited the files greatly to get the gantry operation set up so I suspect I have errors but I cannot spot them and would appreciate any help.
18 Jun 2019 15:15 #137192
by pl7i92
Replied by pl7i92 on topic Y axis has two joints and they move in opposite directions
Hi
it is best practise to give one of the Steppers a wire SWITCH
Switch from
A+ A- B+ B- to
A- A+ B- B+
only on one
YOU Can invert the DIR output pin of the one that is nearest cable
depending on what controller you got
setp parport.0.pin-03-out-invert 1
net ydir => parport.0.pin-03-out
Switch from
A+ A- B+ B- to
A- A+ B- B+
only on one
20 Jun 2019 12:31 #137370
Replied by andypugh on topic Y axis has two joints and they move in opposite directions
As well as swapping wires or inverting the dir pin you can try setting [JOINT_2]SCALE = -6400
But only do one of these three things or they will cancel out.
20 Jun 2019 12:36 #137373
by pl7i92
best advise is always to
swapping wires
as it does not interfear any software calculation
swapping wires
20 Jun 2019 14:53 #137388
by AgentWD40
I'm curious, where would this cause problems with the software?
Replied by AgentWD40 on topic Y axis has two joints and they move in opposite directions
swapping wires
20 Jun 2019 18:51 - 20 Jun 2019 19:05 #137407
Well, when I suggested a negative scale I couldn't decide whether the homing directions needed to be switched too.
In the end I decided not. But the fact that I had to think about it hints at the problem.
Last edit: 20 Jun 2019 19:05 by andypugh.
- norbertfarquharsh
21 Jun 2019 14:09 #137488
Replied by norbertfarquharsh on topic Y axis has two joints and they move in opposite directions
I thank you for all your comments. I am attaching my .ini and .hal files after I worked on them yesterday
Yesterday was the first I had been able to work on this.
This is a machine that had worked until I recently found out about 2.8 and downloaded it and installed it. So I was puzzled why the wiring would have gone bad. I figured I had made mistakes when I did the hand edits on the files after generating them with stepconf.
So yesterday I tried different arrangements of the inversion of the y0 and y1 joints and with both not inverted they both go in the same direction. Now all I have to do is to get the Y axis so that it goes in the right direction when it tries home.
Thanks again.
Thanks again.
21 Jun 2019 14:23 #137490
by bevins
Change the sign of home_search_vel. I think thats the correct one.
Homing Docs
Replied by bevins on topic Y axis has two joints and they move in opposite directions
I thank you for all your comments. I am attaching my .ini and .hal files after I worked on them yesterday Yesterday was the first I had been able to work on this.
Thanks again.
Homing Docs
- norbertfarquharsh
22 Jun 2019 14:41 #137591
Thank you very much for that. I had printed out the homing part of the linuxcnc documentation but had not looked through it yet but I tried the change you suggested
and all is well.
and all is well.
12 Apr 2024 21:17 #298130
by visharc
Replied by visharc on topic Y axis has two joints and they move in opposite directions
[justify]Hello I am new here I am also facing a similar problem .I am setup my stepconf for tandem y axis (Dual y axis) when i am jogging the machine in direction it works fine but when i jog it in - direction both y axis motors moves in opposite direction and throws my gantry out of square
solution i have tried[/justify]
I have attached my ini and hal file help me out
This is the driver i am using
[/justify]
- Swapping wires on driver
- inverting Dir pin
- Putting negative scaling for one of the y motor
- changing the direction in my Driver
[/justify]
Time to create page: 0.294 seconds
