- Configuring LinuxCNC
- Basic Configuration
- ATC doesn't work - Error need Tool prepared Txx-for Toolchange
- JB-Motoring
27 Jun 2019 22:15 #138038
by JB-Motoring
Hey folks,
My ATC doesn't work as planned.
I've got the Toolchange file of a user with pretty the same machine and the same mesa cards (7i92 7i77 7i74 7i70 7i71).
But there must be a mistake in my hal or ini file, because it isn't working with the same file- the ios are named the same.
Everytime I try Tool 1-12 (Basket type toolchanger - Chiron FZ12) the error need Tool prepared Txx-for Toolchange occurs.
I've searched for the mistake all day long, without any results.
The whole machine works perfect with the original Siemens 810m, so there can't be a hardware mistake.
Maybe someone can help me with that, that would be reeeeaaaaaaaally awesome!
Thank you guys
Thank you guys
27 Jun 2019 23:36 #138052
by BigJohnT
Replied by BigJohnT on topic ATC doesn't work - Error need Tool prepared Txx-for Toolchange
You have some M1xx files that may be the issue.
This is the manual tool change hal.
So look for iocontrol.0.tool-prepared to make sure it is being set.
Open a terminal and use grep it's your friend.
JT
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
grep -irl 'iocontrol.0.tool-prepared' *
JT
- JB-Motoring
28 Jun 2019 11:10 #138111
by JB-Motoring
Replied by JB-Motoring on topic ATC doesn't work - Error need Tool prepared Txx-for Toolchange
Hey JT,
thanks for the note.
The thing is, the current NGC is running with no problems on another machine, so the file doesn't seem to be the main problem?
I think my hal is incorrect for that.
All the M commands are in the folder also, should I upload these files also?
Thanks guys!
Thanks guys!
28 Jun 2019 17:50 #138129
by pl7i92
Replied by pl7i92 on topic ATC doesn't work - Error need Tool prepared Txx-for Toolchange
did you set the user M_path correct
USER_M_PATH = myfuncs:/tmp/mcodes:experimentalmcodes - Specifies a list of colon ( separated directories for user defined functions. Directories are specified relative to the current directory for the ini file or as absolute paths. The list must contain no intervening whitespace.
A search is made for each possible user defined function, typically (M100-M199). The search order is:
[DISPLAY]PROGRAM_PREFIX (if specified)
If [DISPLAY]PROGRAM_PREFIX is not specified, search the default location: nc_files
Then search each directory in the list [RS274NGC]USER_M_PATH
The first executable M1xx found in the search is used for each M1xx.
Note
The maximum number of USER_M_PATH directories is defined at compile time (typ: USER_DEFINED_FUNCTION_MAX_DIRS == 5).
Note
- JB-Motoring
29 Jun 2019 10:01 #138168
by JB-Motoring
Hey,
the path is set correct.
Each Mcode works, when i type it in MDI.
- JB-Motoring
29 Jun 2019 14:54 #138178
by JB-Motoring
So me again :-D
I am going to rewrite the whole Toolchange process, the one I got may be working, but it is hard to understand, what the autor wrote in that script.
So, what will the machine do in an automatic tool change ?
1. Unclamp tool
2. Move down the tool-basket
3.Spindle clean with air
4. Move all tool arms up (12 tools mounted in seperated arms, one output that moves all T's up at a time)
5.S220 M3 (Spindle must stay on at about 200 RPM while inserting a tool- there is a spring that notches in the tool automatically)
6.Spindle clean off
7.Clamp tool
8. M5
9. Move up tool-basket
10. DONE
HOW that has to look like can you see here :
The tool change can be done everywhere in the machine- BUT it needs 90mm to the highest Z where it is changing, because the tool will move 90 mm out of the spindle to get changed.
So the best would be a G53 Z0 to postion the Spindle out of any collision zone.
I would say, that it is not that difficult to write a script, that works correct...But I don't know, how to start.
Maybe someone can give me an example how to do it the easiest way.
Thanks guys !!
1. Unclamp tool
6.Spindle clean off
7.Clamp tool
8. M5
10. DONE
Thanks guys !!
30 Jun 2019 11:54 - 30 Jun 2019 12:04 #138232
by BigJohnT
You have laid out the steps so you have the first part done. I would next write a G code file to change one tool and work out the details. Use a parameter for the tool number so you can test different tools.
linuxcnc.org/docs/2.7/html/gcode/overvie...ml#_named_parameters
Once that is done you can convert it to a subroutine and call that subroutine in your G code file while passing the tool number to the subroutine.
linuxcnc.org/docs/2.7/html/gcode/o-code.html
To trigger digital outputs from G code you use M62-65.
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m62-m65
I assume your using version 2.7 so I'm linking those documents.
JT
JT
Last edit: 30 Jun 2019 12:04 by BigJohnT.
30 Jun 2019 13:20 #138234
by BigJohnT
I need to add that the documents do a poor job of explaining what happens when a Tx is issued.
iocontrol.0.tool−prep−number
(s32, Out) The number of the next tool, from the RS274NGC T-word
iocontrol.0.tool−changed
(Bit, In) Should be driven TRUE when a tool change is completed.
linuxcnc.org/docs/2.7/html/man/man1/iocontrol.1.html
JT
JT
- JB-Motoring
02 Jul 2019 21:02 - 02 Jul 2019 21:04 #138437
by JB-Motoring
Hey guys,
something happened,
So I managed to: Open the spindle, flood the spindle, open the spindle, move down the basket, move up all tools -> NEXT STEP would be Insert a tool, so move down one arm with one tool (12 tools eg. 12 arms).
BUT I don't get it done right.
I attached the files for it- M118 is the Tool insert cycle, that isn't working- the 12 outputs are all named like o-tool-xx-down.
How do I set it up?
Thanks for all the help!
something happened,
How do I set it up?
Last edit: 02 Jul 2019 21:04 by JB-Motoring.
02 Jul 2019 23:04 #138455
Replied by andypugh on topic ATC doesn't work - Error need Tool prepared Txx-for Toolchange
Your M118 would need to poll the inputs (halcmd getp) or it will never see the state change.
I would suggest that the M118 is probably superflous. Set up a G-code digital input for each tool and use M66 wait-on-input in the G-code routine.
The following user(s) said Thank You: JB-Motoring
Time to create page: 0.251 seconds
