- Configuring LinuxCNC
- Basic Configuration
- ATC doesn't work - Error need Tool prepared Txx-for Toolchange
03 Jul 2019 00:14 - 03 Jul 2019 00:15 #138470
by BigJohnT
Replied by BigJohnT on topic ATC doesn't work - Error need Tool prepared Txx-for Toolchange
This could be done in ClassicLadder, I have a Lathe Turrent example you might want to look at.
gnipsel.com/files/linuxcnc/configs/cl-turret-sim.zip
Or as I mentioned above use parameters to select the tool.
For example if T6 is issued then iocontrol.0.tool−prep−number has the value of 6 and you can test that 12 times to see what tool to load.
JT
JT
Last edit: 03 Jul 2019 00:15 by BigJohnT.
The following user(s) said Thank You: JB-Motoring
- JB-Motoring
03 Jul 2019 10:01 #138510
by JB-Motoring
Replied by JB-Motoring on topic ATC doesn't work - Error need Tool prepared Txx-for Toolchange
Thank you to again!
Could you give me an example of how it should look like? It's pretty hard to understand, how I need to set it up.
For only one tool would be enough- just to have a line where it has to go.
Thanks guys!
Thanks guys!
03 Jul 2019 13:05 #138522
Replied by andypugh on topic ATC doesn't work - Error need Tool prepared Txx-for Toolchange
Using a remapped G-code
.... (Whatever preparatory unload code you need)
(The following (DEBUG, are to check if the M6 is good or bad here)
(DEBUG, before M6 the param is #<_selected_tool>)
M6 (this sets an internal parameter to the required too number)
(DEBUG, after M6 the param is #<_selected_tool>)
M64 P[ #<_selected_tool> ] (fire the solenoid corresponding to the tool number)
M66 P[#<_selected_tool>)] L1 (wait for the corresponding "loaded success" pin
M65 P(#<_selected_tool>) (retract the changer)
- JB-Motoring
03 Jul 2019 13:13 #138523
by JB-Motoring
Thank you for the fast answer
So lets say,
Tool 01 = P01
Tool 02 = P02
Tool 12= P12
Is that they way I have to set the pins in the postgui?
Thanks all
So lets say,
Tool 01 = P01
Tool 02 = P02
Tool 12= P12
Thanks all
03 Jul 2019 13:25 #138525
It doesn't need to be postgui. You can do it any any HAL file after motmod is loaded.
First you need to make sure that you have enough DIO pins:
linuxcnc.org/docs/2.7/html/man/man9/motion.9.html
(note the "num_dio" parameter. You need to change this in the main HAL file, bit that's OK, I think you can accept that you are finished with stepconf / pncconf now.)
Now connect the hardware inputs and outputs for P1 to motion.digital-in-01 / motion.digital-out-01 and so on
Then realise that I messed up, and almost certainly should have used #<_selected_pocket> in the G-code sample
linuxcnc.org/docs/2.7/html/gcode/overvie...ned-named-parameters
- JB-Motoring
03 Jul 2019 13:30 #138526
by JB-Motoring
Ooookay, I'll give it a try.
I will upload the files after the test, hopefully I understand it all :-D
Sorry for all the questions, but I'm all new to linuxcnc.
Thank you again!
Thank you again!
03 Jul 2019 14:02 #138530
by BigJohnT
Just did a quick test for #<_selected_tool> vs #<_selected_pocket>
When no Tn has been issued 0.0 and -1.0
After a T1 has been issued 1.0 and 1.0
Why use selected pocket for a non random tool changer? But I guess it will always be the correct number... so long as the -1.0 does not cause a problem in the G code.
JT
JT
03 Jul 2019 18:54 #138561
by BigJohnT
I created a simple subroutine from your steps on page 1, I don't see where the tool number is called? Can you put that in the subroutine? I just opened a show hal configuration watch window and added the digital output pins so I could watch them turn on and off.
o<toolchange> sub
; Where do you change the tool by number???
M64 P0 ;1. Unclamp tool
G4P1 ; Pause
M64 P1 ;2. Move down the tool-basket
G4P1 ; Pause
M64 P2 ;3.Spindle clean with air
G4P1 ; Pause
M64 P3 ;4. Move all tool arms up one output that moves all up at a time
G4P1 ; Pause
; After you move them up do you turn off the output???
S200 M3 ;5 Spindle on at about 200 RPM while inserting a tool
G4P1 ; Pause
M65 P2 ;6.Spindle clean off
G4P1 ; Pause
M65 P0 ;7.Clamp tool
G4P1 ; Pause
M5 ;8. Stop the spindle
G4P1 ; Pause
M65 P1; 9. Move up tool-basket
G4P1 ; Pause
; 10. DONE
o<toolchange> endsub
M2
- JB-Motoring
10 Jul 2019 21:27 #139024
by JB-Motoring
Hey guys, sorry for the late reply!
What should I say?
Everything works just like it should, i am so happy, that you showed me, that there es another way to do it.
I will upload the subs tomorrow, maybe they can help someone some Day.
Next step is setting up all Switches for override and axis selection.
I will create a New topic for that, it must be done with mux...
Thanks All!
Greetings
What should I say?
Thanks All!
Greetings
Time to create page: 0.196 seconds
