Linuxcnc always wants to update my INI file
24 Jul 2019 08:31 #140415
by JetForMe
Linuxcnc always wants to update my INI file was created by JetForMe
Every time I launch linuxcnc I get an alert with the message
If I say "Yes" to this, I then get another alert that says
(or whatever value I put in there).
If I say no, it loads normally. But the alert is annoying. What can I do to avoid this?
The [EMC]VERSION information in your INI file indicates that your configuration needs update.
The supplied INI file is already at version 1.6 and should not need updating
- Thank you received: 5959
24 Jul 2019 09:05 #140419
Replied by tommylight on topic Linuxcnc always wants to update my INI file
Version should be 1.1
- Dinuka_Shehan
- Thank you received: 26
24 Jul 2019 16:16 #140437
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Linuxcnc always wants to update my INI file
Download the latest version.
24 Jul 2019 18:24 - 24 Jul 2019 18:26 #140450
by bevins
Replied by bevins on topic Linuxcnc always wants to update my INI file
There's a Version=X in ini file I think. This needs to be changed to something, I forgot, Andy told me one time when I was having the same issue.
EDIT\ Change the line in your ini to read version = 1.1 in [EMC] section. As Todd said...kinda...lol
Last edit: 24 Jul 2019 18:26 by bevins.
- Thank you received: 1370
24 Jul 2019 19:50 - 24 Jul 2019 19:51 #140464
Replied by Todd Zuercher on topic Linuxcnc always wants to update my INI file
I don't remember saying anything?
But if your running Linuxcnc 2.8 or Master (2.9-pre) The ini file as a version line near the beginning. When you import an older configuration Linuxcnc uses that version number to decide if it should run the update conversion script on your configuration or not. (for converting to the new Joints/Axis configuration used in 2.8+.)
Last edit: 24 Jul 2019 19:51 by Todd Zuercher.
24 Jul 2019 21:39 #140478
I think he was refering at me, sorry for disturbing you.
24 Jul 2019 22:44 #140481
by bevins
oops, I meant Tommy
25 Jul 2019 00:42 #140486
by JetForMe
According to the docs : "It’s a good idea to change this number each time you revise your file."
I only bumped it because I was getting the warning before. After bumping it, it went away. Then it came back so I bumped it again.
Replied by JetForMe on topic Linuxcnc always wants to update my INI file
25 Jul 2019 01:08 #140490
I have not yet done much testing on 2.9, but 2.8 requires that to be 1.1
Anything else and it will try to run the wizard to change the version.
The following user(s) said Thank You: JetForMe
25 Jul 2019 01:53 #140492
by JetForMe
So, it sounds like the documentation is incorrect, then.
Time to create page: 0.107 seconds
