Linuxcnc always wants to update my INI file
12 Jan 2020 11:25 #154668
by DC67
Replied by DC67 on topic Linuxcnc always wants to update my INI file
i did it via the selection menu but i had the same problem
12 Jan 2020 17:25 #154694
Replied by andypugh on topic Linuxcnc always wants to update my INI file
Can you zip up the config folder and attach it, I will see if I can tell what is going on.
12 Jan 2020 19:53 - 12 Jan 2020 19:53 #154716
by DC67
Last edit: 12 Jan 2020 19:53 by DC67.
12 Jan 2020 20:41 #154719
This looks like a bug with the "GetFromIni" code in Linuxcnc
The simple workaround for you is to add a blank line (or a comment) before the [EMC] section of the INI.
For some reason if the very first line in the file is the [EMC] section it fails to find it.
I will try to fix that.
But you should be able to just add a line to Fenja.ini and all will be well.
The following user(s) said Thank You: DC67
12 Jan 2020 21:58 - 12 Jan 2020 22:01 #154721
by dgarrett
Replied by dgarrett on topic Linuxcnc always wants to update my INI file
I think the problem is that the ini file was edited with
some program that adds a BOM "byte order mark" (efbb bf) at
the beginning of the file and the parsing in inifile.cc does
not handle BOMs -- not expected in linux.
Ref: en.wikipedia.org/wiki/Byte_order_mark
A brief web search notes that the dos2unix program fixes this:
$ xxd Fenja.ini |head -1
00000000: efbb bf5b 454d 435d 0a23 2054 6865 2076 ...[EMC].# The v
$ dos2unix Fenja.ini
00000000: 5b45 4d43 5d0a 2320 5468 6520 7665 7273 [EMC].# The vers
Last edit: 12 Jan 2020 22:01 by dgarrett.
12 Jan 2020 23:12 #154727
I did look for whitespace in the editor, but the BOM is new to me.
But would certainly mess up the parser that looks for a lie beginning [EMC]
That said, a blank line fixes the issue easily, moving the BOM to an irrelevant line.
13 Jan 2020 15:44 #154766
by DC67
Thanks for the solution. It worked! I wrote a comment in line one that reminds me not to delete this line
Time to create page: 0.119 seconds
