- Configuring LinuxCNC
- Basic Configuration
- Multiple BOB's and parallel ports, and different driver card issues
MANY THANKS TO ALL for the help so far~
- Thank you received: 5932
Or could you post pictures of your bios, it might remind me.
- Thank you received: 1369
Try changing your loadrt hal_parport line to...
loadrt hal_parport cfg="0 out 1 out"
This takes the addressing guess work out of addressing your parallel ports and may highlight if there is a problem with Linux recognizing your 2nd parallel port card.
....... Also, changing "ldrt_parport cfg="0xe010 out 0xd010 out" to cfg = "0 out 1 out" caused an immediate error when loading the GUI.
I can also recall that not working back when i was using 2 or 3 cards in one PC, but it did work when the addresses were used.
In about an hour i will be in my workshop so i can check the BIOS on some of the PC's i have there.
BTW, BIOS is in the PC, it has nothing to do with Debian or Linux as far as this issue is concerned.
On both GUI's I do get a PORT NOT FOUND error that keeps popping up. In AXIS, its when I command a move, in GMOCCAPY, its when the app loads. If I ignore the error, things seem to continue to work.
My next step is to resurrect the original Dell Tower system, and see if the problem remains when I use it's older parallel port card. The system worked solidly for all the time I've had it, but it was getting old and needed new hard drives...and the control box was a complete rats nest of 30 gage wire.
DELL Bios editor does not have any way to set up the parallel port cards. If there is a setup file somewhere that I can edit, that might work. I'll try Dell tech support, but no real hopes there. Let me know if you know of something.
I've got everything working great, BUT with only one card installed. Installing the second card always generates a port not found error, and a real-time error as well. If I can figure out how to get the Vout (Pin1 on the BOB) to give me an on-off signal, then it can control the brake, and I have enough spare inputs to run the limit switchs in parallel.
This has been traumatic.
I found the paper on cleaning up the system, and will go through it on Thursday.
No, the BIOS can only control onboard parallel ports.DELL Bios editor does not have any way to set up the parallel port cards.
Does it halt at that stage, or carry on? Maybe the error is a fault in LinuxCNC. (though you mention that they are on the same IRQ, and that doesn't sound right, though Google does suggest that IRQs can be shared, so perhaps it makes sense that two identical cards would be on the same IRQ).I've got everything working great, BUT with only one card installed. Installing the second card always generates a port not found error.
IF only ONE board is installed, the port not found error may pop up once at some point, then never again. Wtih TWO boards installed, it always pops up right when I load the GUI and crashes the GUI load...Also the real time error (DMESG) shows up too.
Actually I don't know that the cards are on the same IRQ since the reporting by linux gives the IRQ=11 for one card, and nothing for the second...so its may be safe to assume they are one the same port. The installation disk provided only supports Windows OS's.
FYI I tried almost every available parallel port card that fit in the PCIe slots in the Dell motherboard. ONLY the SIIG "Legacy" cards worked at all.
HI
Assuming that the error box pops up, can you click the "select all" button, then Ctrl-C and paste the error listing to a text file and attach it here.
What "loadrt" line are you using when attempting to start both cards?
also pleas can you tell us here what general system did you setup
and where did you get it from
on a standard parport base period shoudt be 100k this leads into a 60k step per second no stepper will meet that so you got lots of time and no following error
