Any help wiring BLDC motor controller to Mesa 7i76?
10 Nov 2019 11:47 #150051
by RoberCNC
Any help wiring BLDC motor controller to Mesa 7i76? was created by RoberCNC
Hi, I have a Chinese BLDC controller for the spindle and I have no idea how to wire it to the Mesa card, I don't even know what the HALL terminal is for, I have found a diagram but it only turns and I think it can take more advantage (turn in both directions, revolutions, etc). I enclose the terminals and pins that you have to see if you can lend me a hand.
Motor Driver:
HALL terminal
V-
HU
HV
HW
V+
CONTROL terminal
F/R
SV
ALM
PG
EN
+10V
GND
Mesa TB4 connector
1 SPINDLE-
2 SPINDLE OUT
3 SPINDLE+
4 NC
5 SPINDLE ENA-
6 SPINDLE ENA+
7 SPINDLE DIR-
8 SPINDLE DIR+
Thanks a lot.
Motor Driver:
HALL terminal
V-
HU
HV
HW
V+
CONTROL terminal
F/R
SV
ALM
PG
EN
+10V
GND
Mesa TB4 connector
1 SPINDLE-
2 SPINDLE OUT
3 SPINDLE+
4 NC
5 SPINDLE ENA-
6 SPINDLE ENA+
7 SPINDLE DIR-
8 SPINDLE DIR+
Thanks a lot.
- Thank you received: 5946
10 Nov 2019 11:59 - 10 Nov 2019 12:01 #150052
Replied by tommylight on topic Any help wiring BLDC motor controller to Mesa 7i76?
Those are for HAL sensors on the motor. Does it have sensor wires or terminals ?Motor Driver:
HALL terminal
V-
HU
HV
HW
V+
Again, you should wait for PCW to confirm that, it's been over 3 years i installed my last 7i76E.Motor Driver:>>>>>>>>>>>>Mesa TB4 connector
CONTROL terminal
F/R>>>>>>>>>>>>>>>>>>>>>>>8 SPINDLE DIR+
SV ??????????>>>>>>>>>>>>>>2 SPINDLE OUT
ALM>>>>>>>>>This can go to an input on 7i76 to show spindle errors
PG
EN>>>>>>>>>>>>>>>>>>>>>>>>6 SPINDLE ENA+
+10V>>>>>>>>>>>>>>>>>>>>>>3 SPINDLE+
GND>>>>>>>>>>>>1 SPINDLE-/5 SPINDLE ENA-/7 SPINDLE DIR-
Last edit: 10 Nov 2019 12:01 by tommylight. Reason: ignores spaces !
10 Nov 2019 12:20 #150054
by RoberCNC
Replied by RoberCNC on topic Any help wiring BLDC motor controller to Mesa 7i76?
Again thank you very much Tommy, no problem waiting
Sensors wires or terminals the motor you mean? No it doesnt, the motor only have 3 wires (U, V and W)
What is the HALL exactly for? just to know and go learning.
Must wait for PCW then
10 Nov 2019 13:02 #150059
There should be 5 more wires ( 8 for differential outputs ) that usually go to the encoder side of the motor for hal sensors that tell the drive at what angle is the rotor inside the motor positioned and subsequently what winding should it energise to move in one direction or the other.
If it does not have them it will work without them, some spindles do not have them, some do.
You are welcomed.Sensors wires or terminals the motor you mean? No it doesnt, the motor only have 3 wires (U, V and W)
15 Nov 2019 16:06 - 15 Nov 2019 16:08 #150434
by RoberCNC
PCW where are you!!!
I need your knowledge.
Tommy I wish I could talk to you would it be possible? How do we do it?
Last edit: 15 Nov 2019 16:08 by RoberCNC.
15 Nov 2019 16:25 #150436
The following user(s) said Thank You: RoberCNC
22 Nov 2019 08:57 #150887
by RoberCNC
Good morning to all. While I wait to see what PCW says I will try the combination that Tommy has suggested. Is there any danger of damaging the Mesa card?
22 Nov 2019 12:55 #150907
Replied by PCW on topic Any help wiring BLDC motor controller to Mesa 7i76?
Do you have a drive manual that shows suggested control wiring?
Note the the 7I76 spindle ENA and DIR outputs are just switches
so you should be able to verify drive operation with mechanical switches
If mechanical switches work for the drives EN and F/R pins, the 7I76 outputs
should work also
should work also
22 Nov 2019 13:14 - 22 Nov 2019 13:19 #150912
by RoberCNC
Right now it is working with a mechanical switch and one of the cables effectively goes to EN, the other to GND together with one that goes to the potentiometer of three pins, the other two cable of the potentiometer go to + 10V and SV.
What I have no idea is how to wire the inputs to 776 to make it work just as the direction of rotation works, etc ...
Thats the info I found from the Seller:
Motor Driver(WS55-220):
Voltage:24-50VDC
Rated Current:14A (Current Limiting is about 15A)
Max. Supporting Speed:20000RPM
Speed Control:1, Connect to external potentiometer; 2, Connect to external 10VDC voltage.
Speed Output:PG signal
--there is a 5V speed pulse output between this port and earth). If output frequency is P(Hz), motor pole
number is N, speed is F(RPM), then output speed frequency, P=F*N/60
Alarm Output:ALM signal, there is alarm pulse output between this port and earth
1.This port outputs 5V high level when normal working;
2. When it is powered on, but speed control signal is quite low and motor does not rotate, port signal is
low level; that is to say, when EN button is open, as long as motor does not rotate, alarm port signal is low
level, indicating the state is abnormal and need to be dealt with;
3. When it is under-voltage, over-voltage, stall, lacking phase or phase short circuit, port signal is low level.
CW/CCW: F/R, external switch connects to F/R port at one end, and to earth at the other end; motor's
rotating direction can be changed.
Start/Stop:En button, external switch connects to EN port at one end, and to earth at the other end;
motor starts when connect to earth.
Stall Protection:Motor stops working when stalled, and starts when powered on again
Power Light:Green light on when powered on
Indicator Light:Red light flashes once at intervals when EN power on, potentiometer or external voltage
not power on; Red light flashes seven times at intervals when EN not power on and on stand-by state.
Insulation Resistance:>100MΩ(normal temperature and pressure)
Dielectric Strength: 0.5KV, 1min(normal temperature and pressure)
Voltage:24-50VDC
Last edit: 22 Nov 2019 13:19 by RoberCNC.
22 Nov 2019 13:55 #150921
So tommylights wiring should be correct
(though you may have to invert the direction signal in hal)
Time to create page: 0.368 seconds
