Any help wiring BLDC motor controller to Mesa 7i76?
23 Nov 2019 11:52 #151037
by RoberCNC
Replied by RoberCNC on topic Any help wiring BLDC motor controller to Mesa 7i76?
Thanks mates, the wiring works perfect! turn on, clockwise, counterclockwise all good.
I only have 2 obstacles:
1-when I tell it to work counterclockwise by default it starts at full speed and I have to press the + button to reduce revolutions.
2-the range shown in the virtual display does not correspond to reality, supposedly reaches 20,000 revs, but it marks from 0 to 3000 and from 1600 does nothing apparently.
How can I adjust and fix that?
- Thank you received: 5946
23 Nov 2019 12:40 #151040
Replied by tommylight on topic Any help wiring BLDC motor controller to Mesa 7i76?
Invert the spindle output, if possible.
23 Nov 2019 15:06 #151046
Replied by PCW on topic Any help wiring BLDC motor controller to Mesa 7i76?
I suspect the problem with counter-clockwise speed is that you are sending a negative
spindle speed command to the 7I76.
There are a couple fixes for this in hal depending on LinuxCNC version
Can you post your hal and ini files and indicate your maximum spindle RPM?
23 Nov 2019 16:03 - 23 Nov 2019 16:04 #151055
by RoberCNC
Sure! Here you have them. The Linuxcnc version is the 2.8.0. The maximum RPMs are 18000
Last edit: 23 Nov 2019 16:04 by RoberCNC.
23 Nov 2019 16:36 - 23 Nov 2019 16:37 #151063
in the ini file change the spindle settings to
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 18000.0
OUTPUT_SCALE = 18000
OUTPUT_MIN_LIMIT = 0
OUTPUT_MAX_LIMIT = 18000
in the hal file, change
net spindle-vel-cmd-rpm => pid.s.command
to
net spindle-vel-cmd-rpm-abs => pid.s.command
[SPINDLE_0]
P = 0.0
I = 0.0
D = 0.0
FF0 = 1.0
FF1 = 0.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
to
Last edit: 23 Nov 2019 16:37 by PCW.
The following user(s) said Thank You: RoberCNC
23 Nov 2019 17:27 #151067
by RoberCNC
Thank you very much PCW, both details solved. Real RPMS is a mystery, it always has a dead range both below and above, if I put 18000, in the range of 0 to 3500 + - it doesn't work, and if I put 1800 the same thing happens from 0 to 400. Anyway Thank you very much, something new that I learned today.
Time to create page: 0.144 seconds
