Need help with direction.
01 Dec 2019 17:23 #151669
by jeffie-3
Need help with direction. was created by jeffie-3
Hello, I am a novice, that is for sure. I can really use some guidance.
All of the electronics is complete on a Bridgeport retrofit. New servos, encoders, huanyang vfd, 5i25, 7i77 mesa boards. The computer is a Dell Optiplex 780. Running Ubuntu Precise, LinuxCNC 2.7.8. I am having a bit of trouble with linux. Can't install a network printer, and some of the desktop icons are missing and when booting a usb port 1 gives an error message. Do I need to re install linux? Better version Debian Wheezy?
So here is what I think should be the procedure for getting the software to work.
1. Latency Test
2. Run Hal
3. Setup Huanyang VFD
4. Run PNConf
5.Homing Configuration
6. Tune the servo motors.
7. Calibration from AXIS.
Am I on the right track? Missing anything basic? Anything out of order or missed?
Than you,
Jeff
1. Latency Test
2. Run Hal
4. Run PNConf
Than you,
Jeff
- Thank you received: 5957
01 Dec 2019 18:11 #151680
If you are getting USB errors with nothing inserted, that board/USB had a nasty surprise during it's life time.
Replied by tommylight on topic Need help with direction.
You need to change the PC, not Linux.Can't install a network printer, and some of the desktop icons are missing and when booting a usb port 1 gives an error message. Do I need to re install linux?
The following user(s) said Thank You: jeffie-3
01 Dec 2019 18:22 #151682
by jeffie-3
Replied by jeffie-3 on topic Need help with direction.
Thank you,
At this time I can't replace the computer. I have the keyboard and mouse on the other usb ports. They seem to be working. But I will put another P.C. on the list of things I need to replace.
01 Dec 2019 18:54 #151683
by Leon82
Replied by Leon82 on topic Need help with direction.
There should be a motherboard pin connection to add a USB for the case you could try
01 Dec 2019 22:29 #151708
03 Dec 2019 13:06 #151849
I would not suggest Wheezy _or_ precise. Both are ancient and out of support.
You are using Mesa cards, so use the Debian Stretch ISO with preempt-rt.
linuxcnc.org/downloads/
Replied by andypugh on topic Need help with direction.
05 Dec 2019 19:10 #152087
by jeffie-3
Will I lose all my setting when installing?
05 Dec 2019 20:25 #152099
by bevins
Replied by bevins on topic Need help with direction.
Make a copy of your config folder.Will I lose all my setting when installing?
23 Dec 2019 15:52 #153111
by jeffie-3
O.K. I put Debian Stretch on a jump drive. Booted to it. Everything went well. When I turned off the machine and turned it back on. I was back to Ubuntu Precise. Grub did not show Debian. What did I do wrong?
- Thank you received: 1370
23 Dec 2019 17:26 #153121
Replied by Todd Zuercher on topic Need help with direction.
Are you sure you actually installed Stretch to your HD, or did you just run it "live" from your USB stick?
Time to create page: 0.174 seconds
