Step/Dir Servo Spindle Kicking My Butt - No Reverse
- Mike Connelly
02 Apr 2023 07:14 - 02 Apr 2023 13:16 #268055
by Mike Connelly
Step/Dir Servo Spindle Kicking My Butt - No Reverse was created by Mike Connelly
I've spent months trying to get a step/dir servo spindle working, and am asking for any help I can get. It's a DMM DYN4 drive and 750w motor, and I'm running a 7i76e controller.I have forward speeds (M3) working properly, but M4 commands are completely ignored. The spindle doesn't move, and nothing related to reverse (or the spindle for that matter) shows as active in halshow.
Any help getting M4 reverse working would be greatly appreciated. I'm running Probe Basic if that makes any difference.
.hal and .ini files attached.
Thanks!
Thanks!
Last edit: 02 Apr 2023 13:16 by Mike Connelly. Reason: Figured out part of my problem since I left this post last night. Sleep is so overrated!
02 Apr 2023 14:59 #268077
Replied by PCW on topic Step/Dir Servo Spindle Kicking My Butt - No Reverse
Are you saying that spindle.0.speed-out-rps is 0
when you command a reverse spindle speed?
- Mike Connelly
02 Apr 2023 20:33 #268112
by Mike Connelly
Replied by Mike Connelly on topic Step/Dir Servo Spindle Kicking My Butt - No Reverse
Yes, spindle.0.speed-out-rps is 0 . When I issue M4Sxxxx commands nothing happens, no errors or anything. Reverse doesn't work manually from the GUI either.
Attached are screens shots of selected halshow variables when M3 and M4 commands are issued.
Thank you.
Thank you.
02 Apr 2023 21:18 - 02 Apr 2023 21:19 #268115
Last edit: 02 Apr 2023 21:19 by PCW.
- Mike Connelly
02 Apr 2023 21:43 #268119
by Mike Connelly
I'm running 2.10.0~pre0 , and have the same problem running Axis or Probe Basic.
02 Apr 2023 21:55 #268121
OK. I'm running 2.10 so it looks like it has to be a ini/hal issue.
Can you start linuxCNC
Then issue a mdi command:
m4 s1000
and post the result of this command:
halcmd show all | grep spindle > spindle.txt
m4 s1000
- Mike Connelly
02 Apr 2023 22:04 #268122
by Mike Connelly
Indeed. See attached.
02 Apr 2023 22:27 - 02 Apr 2023 22:28 #268123
And that's after
M4 s1000
M4 s1000
Last edit: 02 Apr 2023 22:28 by PCW.
- Mike Connelly
02 Apr 2023 22:28 #268124
by Mike Connelly
Yes.
03 Apr 2023 03:13 #268142
Well pretty mysterious
My config has no halui connections so I wonder if this is a halui issue?
Time to create page: 0.251 seconds
