Newbie need help, touch plate making.
30 Oct 2023 13:51 #284126
by masawee
Newbie need help, touch plate making. was created by masawee
i have linuxcnc 2.8.4-1-gb 7824717b and has try make touch plate button and subroutine to my cnc. but not understand, all manual what i has search internet say need add many file to many folder but my cnc not have all thats manual say folders.
my pc have masa/linuxcnc/config. folder have only config, and nc_files folders.
and under config folder have only
by_interface,parport.gantry
my-machine
my-mill
sim.axis
sim.gtvcp.screen
Ztouch,xml
my-machine,stepconf
and under
masa/linuxcnc/config/my-machine have
macros (i has make,have empty)
subroutines (i has make,have empty)
custom.hal
custom_postgui.hal
tool.tbl
custompanel.xml
pyvcp_options.hal
postgui_call_list.hal
my-machine.pref
my-machine.ini
my-machine.hal
rs274ngc.var
linuxcnc.var
and problem have internet help manual say i need add xxx files to
ui.hal folder
subroutines folder.
config folders need add Ztouch.xml
subroutines folder need add Gcode i not know how name.
postgui.hal folders need add mdi command but not have postgui.hal file anywere.
and somewere file need add somethink under rs274 and display or other section but not found this file anywere.
need help, how i make touch button to display, were folders need add and what need add.
how make subroutine code move measure bit height and zero position to workpiece top 00.00 and calculate touch plate tighnes out thats.
i have G-code example what i has try run, but not working
G-code
0 Z_touch sub
G10 L20 P0 Z0
G91
G38,2 Z-10 F 25
G92 Z 3 (plate tichness)
G0 Z 1 F10
G38,2 Z-1 F1
G92 Z 3
G90
G0 Z 10 F 25
0 Z_touch end sub
i not understand were thats code need add and what all folders need be.
have any make this touch system yotube video can understand how this make. i not understand good english, im finnish.
my-machine
my-mill
sim.axis
sim.gtvcp.screen
Ztouch,xml
my-machine,stepconf
and under
custom.hal
custom_postgui.hal
tool.tbl
custompanel.xml
pyvcp_options.hal
my-machine.pref
my-machine.ini
my-machine.hal
rs274ngc.var
linuxcnc.var
ui.hal folder
subroutines folder.
G-code
0 Z_touch sub
G10 L20 P0 Z0
G91
G38,2 Z-10 F 25
G0 Z 1 F10
G38,2 Z-1 F1
G92 Z 3
G90
G0 Z 10 F 25
0 Z_touch end sub
03 Nov 2023 09:34 #284423
by masawee
Replied by masawee on topic Newbie need help, touch plate making.
i not understand, forum have make help linuxcnc users, but ewery only looking question but any not answer and help newbie how need make touch plate system to cnc.
- Thank you received: 5944
03 Nov 2023 13:38 #284450
Replied by tommylight on topic Newbie need help, touch plate making.
Sorry Masawee but i never used a touch plate so i can not help, but i did read it twice till now.
05 Nov 2023 08:53 #284602
by masawee
ewery cnc need be touch plate system, important use ewery time when change bit. its basic normal job ewery cnc machine need be in machine this, all normal cnc user must use tool height settig ewerytime if change bit, basic proces do ewery bit first, how can use cnc if not have setting bit right height and zeroing. not can.
05 Nov 2023 10:48 #284607
by MaHa
Replied by MaHa on topic Newbie need help, touch plate making.
If you google for cnc toolsetter, some results of seller may show.
Years ago i made toolsetter myself, both need only a few parts. One larger item with induction switch, not so difficult to do, if some machines are available.The other one, pancake style, optoelectric, is more difficult to do, as the parts must be pretty accurate. It is mainly used now, because of the size and weight.The are no drawings available anymore, so this is just for inspiration, what can be done with little effort.
Then the probing routine is another task, some interface have already probing integrated, or routines are found in this forum.
05 Nov 2023 11:24 - 05 Nov 2023 11:38 #284609
by masawee
i have 2 different tool setter, full aluminium corner tool, can zeroing all Z X Y corner. and 3D printer Z tool what have inside spring center box and under have 3 pcs micro switch whit led. bit press steel plate down and connect 3 pcs micro switch. has jlpcb circuitboard and name has all files MIOCNC all files same site, pcb and 3Dprinted case. part list and wiring, pcb i orden JLPCB 7$ and solder SW and LED and resistor to board. 3D printing case. linuxcnc 2.8.4 i has test and both tools working well at hallmeter TRUE/FALSE paraller port controller pin 15.
3Dprinted case have same style than you pictures have. but i not understand my poor english how were add all files and code.come error all time MDI command = 00. i not know were need add all files, ini, hall, subroutine,xml, button code, etc, not understand good english and ztouch example not has translate good, not tell good were need add all codes,
i has search google many many example but not have lot last 2 month i has try make this.
Last edit: 05 Nov 2023 11:38 by masawee.
05 Nov 2023 13:00 #284616
by chris@cnc
Replied by chris@cnc on topic Newbie need help, touch plate making.
Your questions are not easy. And there is a great danger that it will end in a mess. And we should answer the questions one after the other. what's your language? What/which routine do we start with?
05 Nov 2023 13:38 #284619
by masawee
wery easy, what code need add to were folders, what in ini file need add, what need hal file add, what need subroutine file add and path and were, were need touchplate.xml button file add, were need touchplate,ngc file add, what more need do code and files what need add, were, touchplate button go to display and bush button do Z tool height job, G-code.
05 Nov 2023 13:56 #284623
by chris@cnc
forum.linuxcnc.org/42-deutsch/50537-werk...ports-der-mesa-7i96s
I was just discussing this recently. unfortunately in German. this is for the z height. I'm not at home at the moment. maybe you can try it here. and let's see what's still missing this evening.
05 Nov 2023 14:30 #284630
by masawee
thanks but not help anythink, germany not good translate normal human language all go wrong, and peoples who use first time all life linux and linuxcnc and not has newer before read or write any code not understand code anythink, and i need only help, were i add example Ztouchplate all codes, i not has newer before use code,linux or liuxcnc. need know how make button, how button answer to bush and how do what g-code want doing. were all this code and parts need add, wery simple answer if know. button code need add to folder xxx. parallerport pin 15 need add to xxx file. xml code need add to xxx file or folder. ngc file need add this folder xxxxx. but any people not has answer to me were need add all file parts.
touch plate need only build button first, then hall meter test pin 15 working, my machine pin 15 working ok, whit hallmeter.
then build how answer to button move spindle to right place and do G-code 38.2 procedure. were this need add folderxxxx. and what other need add. wery simple answer if have linuxcnc user .
but i ask thats because i not has newer before make code, write code, add code to linuxcnc, used linuxcnc before newer and need know were i add all file parts.
i has try search thats last 2 month in google but not found any help, all have only other mach3 sites and videos, or expensive mesa card systems, i not have mesa card i not know what this doing and not newer can buy expensive mesa card, i use only paraller controller board, and first time all my life linux and linuxcnc software all have new and not newer has before all my life write any code, im not have computer guru pro im old 65 year men who build cnc machine my young son garage,help him build own garage woodworking shop. my machine have normal sterppermotor cnc size 1200mm x 1200 x 300. only woodworking hobby in garage. simple cheap chinese paraller port board 5 axis board and use 4 stepper motors nema 23 470oz. 4A, spindle have better than router have air cooled 800W ER16 0-30 000rpm. and use first time all my life linux. and want use linuxcnc because have FREE not need expensive licence. need only know how add touchplate working can set up tool height after change bit. thats is normal set up ewery cnc after change bit. basic job but linux have lot different than windows use, not understand linux and code anythink.hardware have easy simple, but this code system not have simple, need help were all code need add. what folders and what path need add button code i has copy to internet, G-code example i has copy, but were all need add.
Time to create page: 0.190 seconds
