Newbie need help, touch plate making.
05 Nov 2023 16:49 #284638
by chris@cnc
Replied by chris@cnc on topic Newbie need help, touch plate making.
How would you like to start touching? with an M code? or a button in the pyvcp panel in gui axis?
05 Nov 2023 16:49 #284639
by MaHa
Replied by MaHa on topic Newbie need help, touch plate making.
If you have all the required files already, can you post this files, to check. (the probing will for shure not run, as is), just guessing the names:
If the folder masa/linuxcnc/config/my-machine , masa/linuxcnc/nc_files , masa/linuxcnc/subroutines
are there, grab files from this folder.
touchplate.xml
touchplate.ngc
your machine.ini
your machine.hal
According the first post, there is kind of a mess in your config folder, which makes it easy to edit the wrong file.
Just stick to the masa/linuxcnc folder.
If this ever works, this setup is for 1 ngc file for each tool
touchplate.xml
touchplate.ngc
your machine.ini
your machine.hal
05 Nov 2023 17:22 - 05 Nov 2023 17:29 #284640
by masawee
Replied by masawee on topic Newbie need help, touch plate making.
not start, not can run cnc, only come error MDI command =00 not found.
answer to M code replies.
Last edit: 05 Nov 2023 17:29 by masawee.
05 Nov 2023 17:28 - 05 Nov 2023 17:30 #284642
by masawee
ok,i move all this files to masa/linuxcnc folder, and try start again.
answer to file location replies.
Last edit: 05 Nov 2023 17:30 by masawee.
05 Nov 2023 17:40 #284647
by MaHa
Sorry, seems there was a missunderstanding. I did not ask to move the files, just to be aware what files you use.
I asked, to post the 4 files i mentioned before, as attachment, to have a look, how to make this setup running. Its impossible to solve, just by advise
05 Nov 2023 18:10 #284651
by masawee
sorry my bad english, i zip my cnc folder masa/linuxcnc/config folder to zip, minun-kone =my-machine. language.
05 Nov 2023 20:16 #284659
by chris@cnc
Well, your questions are really not so easy as you might.
I guess your ini call minin-kone.ini
First, you want to try tool touch off with button in pyvcp panel. Useful information if you want that will someone help.
1. Create button and add xml file to Display Section in ini.
"PYVCP = Ztouch.xml"
2. Link the button in custom_postgui.hal file
3. link mdi command in ini File -> HALUI Section and link your touch program path in RS274NGC Section
I use different way and call my touch program 9000.ngc
I didn't get working with filenames like touching.ngc
I correct your config. There were some grammar errors. Give a try and check what happens and what i change.
06 Nov 2023 08:49 - 06 Nov 2023 09:14 #284689
by masawee
thanks you try help, i not understand what need add ini file inside section, NO;2 what need do custom_postgui.hal
3. how link at MDI COMMAND to hal,ui section ?
link RS274ngc ????
thats all must do inside ini file ? i understand i need add "PYVCP = Ztouch,xml" under DISPLAY section.
but not understand what need add 2. custom:postgui
what need do MDI command
what do RS274NGC
need i copy - paste this new config folder to my linux old config folder replace all config folder new, ?
have you 9000.ngc code metric or imperial ?
i use metric because live in north europe Finland.
link RS274ngc ????
what do RS274NGC
Last edit: 06 Nov 2023 09:14 by masawee.
06 Nov 2023 09:52 - 06 Nov 2023 10:37 #284691
by masawee
i copy - paste new config folder to computer and "touch off Z" button come to display, BUT if bush button come error.
" EOF in file :/usr/share/axis/image axis.ngc seeking O-word: O <9000> from line O.
what this mean ?
my linux not found folder usr/share/axis/image anywere.
not has usr/share folder
edit: i found axis.ngc 1 hour search all linux, this folder but inside code i not understand any, what have wrong ?
geany show line numbers but not have line 0, start line 1,2,3,4,5,6 etc.
what this mean ?
Last edit: 06 Nov 2023 10:37 by masawee.
06 Nov 2023 10:00 - 06 Nov 2023 10:02 #284693
by chris@cnc
I do all that and save it in new configuration. Check the new ini and postgui file in zip folder. The only one missing is the path of 9000.ngc in your environment. I marked in ini file. If you start the new config you should get error 9000.ngc not found. In this case fix the path. Try it and we will see what error comes next. Try and error. Sometimes only way to learn. I will try tonight write a more clear example. On the mobile phone not possible.
Last edit: 06 Nov 2023 10:02 by chris@cnc.
Time to create page: 0.576 seconds
