PathPilot on AMD GizmoSphere 1
20 Nov 2015 16:39 #65576
by Iron-Man
Yes I tried man mux16 but nothing showed up.
Thanks,
Iron-Man
Replied by Iron-Man on topic PathPilot on AMD GizmoSphere 1
Have you looked for the man page from a terminal?
linuxcnc.org/docs/html/hal/components.htmlman mux16
Rick G
Thanks,
Iron-Man
20 Nov 2015 16:42 #65577
Replied by andypugh on topic PathPilot on AMD GizmoSphere 1
mux_generic can do anything that mux16 can do, and more.
Also be aware that the module names are likely to be case-sensitive.
21 Nov 2015 13:35 - 21 Nov 2015 13:41 #65601
by Iron-Man
I should be able to post later this week but the modules mux4, 16, generic, are not at this location;
operator/tmc/rtlib. The only mux module located there is mux2.ko. what I need to do is connect the MPG to the 7i77. This was easy under Linuxcnc by modifying the posted example that uses mux4. Later this week I will extract the modules from another computer and see if it works.
If any of the Tormach / PathPilot people are looking at this, my question would be, did you remove some of the mux modules?
Thanks Andy/ Cncbasher
Iron-Man
Iron-Man
Last edit: 21 Nov 2015 13:41 by Iron-Man. Reason: Additional info.
21 Nov 2015 14:14 - 21 Nov 2015 14:25 #65602
by cncbasher
Replied by cncbasher on topic PathPilot on AMD GizmoSphere 1
which version of pathpilot do you have ?
did you compile from source ?
i can send them if you need
although the mux files are in the source .
and looking at the source a bit deeper it does look as if only mux2 is copy'd across to tmc , along with quite a few others trimmed out
so their version of linuxcnc is cut down quite a bit .
Last edit: 21 Nov 2015 14:25 by cncbasher.
The following user(s) said Thank You: Iron-Man
21 Nov 2015 14:24 #65603
by Iron-Man
I purchased the DVD and loaded it direct. I upgraded to ver 1.9.3.
Thanks,
Iron-Man
Thanks,
Iron-Man
21 Nov 2015 14:29 #65604
by cncbasher
sent you a pm
21 Nov 2015 14:36 #65605
by cncbasher
here's the mux files , just add to rtlib folder
21 Nov 2015 14:39 #65606
by Iron-Man
Thanks !!
Iron-Man
Iron-Man
21 Nov 2015 14:40 #65607
by cncbasher
charge-pump is missing also
21 Nov 2015 14:50 #65608
by Iron-Man
Can you send that file?
Iron-Man
Iron-Man
Time to create page: 0.172 seconds
