ubuntu 14.04.1 linuxcnc help
- Razor_keen
- Thank you received: 4
17 Dec 2015 00:03 #67058
by Razor_keen
Replied by Razor_keen on topic ubuntu 14.04.1 linuxcnc help
seems to work though. should we try to run it on every flavour to ensure compatibility? Im stubborn enough to do it. im working on downloading a few isos for the diffrent os. i want to start with a debian system. unless you have specific priorities.
17 Dec 2015 00:11 #67059
by tjmarch
Replied by tjmarch on topic ubuntu 14.04.1 linuxcnc help
With Ubuntu I do not install package in Software Center I grab it from here with the extension pack
www.virtualbox.org/wiki/Downloads
you want
VirtualBox 4.3.34 for Ubuntu 13.04 ("Raring") / 13.10 ("Saucy") / 14.04 ("Trusty") / 14.10 ("Utopic") i386 | AMD64
I know it says it is the same version but it is a little different
you want
17 Dec 2015 00:13 - 17 Dec 2015 00:21 #67060
by tjmarch
Jason
It will not work on Debian I have already tried it, just Ubuntu and Mint . I plan on trying it on all flavors which would you prefer to test Ubuntu or Mint or a little of both.
Last edit: 17 Dec 2015 00:21 by tjmarch.
- Razor_keen
17 Dec 2015 01:01 - 17 Dec 2015 01:05 #67061
by Razor_keen
im currently downloading every flavor of mint, since they were all on the same page, ill wait the half hour it will take then do the ubuntu isos. your call. im having to juggle my time right now, i will post which systems i tested as i tested them, and hopefully my phone will not ring so much. im on call this week.
Last edit: 17 Dec 2015 01:05 by Razor_keen.
17 Dec 2015 01:02 - 17 Dec 2015 01:09 #67062
by tjmarch
Jason
Let me test the 64 bit installs my work laptop is a I7 and has allot of memory and I can dedicate multiple CPU's to VM
The problem you were having might be if you have not installed extension pack within the guest OS of VM.
I will try to download ISO's tonight when I get home at work, here they have the internet throttled back it will take over 2 hours just for one ISO
Last edit: 17 Dec 2015 01:09 by tjmarch.
- Razor_keen
17 Dec 2015 01:07 #67063
by Razor_keen
makes sense. ill work on al 32 bit installs, ubuntu and mint.
17 Dec 2015 01:16 - 17 Dec 2015 01:17 #67064
by tjmarch
Note within a VM when you start lcnc you will get realtime delay faults. It should still run if it fails close lcnc then retry. That is because latency is so high in VM and there is nothing you can do about it. If a install will not run for you in VM let me know and I will try on my desktop sometimes it makes a difference in realtime OS.
Last edit: 17 Dec 2015 01:17 by tjmarch.
17 Dec 2015 05:22 #67066
by tjmarch
Jason I am not going to check
Edubuntu
Ubuntu Kylin
Mythbuntu
Ubuntu Studio
Ubuntu MATE no 14.04 release
Edubuntu
Ubuntu Kylin
Mythbuntu
Ubuntu Studio
- Razor_keen
17 Dec 2015 23:49 #67115
by Razor_keen
Virtual box is moving much slower than i would like. I have extra hard drives, it might be easier for me to just use a different hdd. i'll print out a disc with as many os's as i can fit then i can just do a disk install on it. I should be able to fit 3 maybe four a disc.
19 Dec 2015 00:37 - 19 Dec 2015 00:39 #67139
by tjmarch
Jason
64 bit install from ISO worked with all that I checked which included Linux Mint 17.1 and 17.2 and 17.3
What I checked
Mint
Cinnamon (64-bit)
KDE (64-bit)
MATE (64-bit)
Xfce (64-bit)
Ubuntu 14.04.3
Ubuntu.desktop (64-bit)
Ubuntu GNOME (64-bit)
Kubuntu (64-bit)
Lubuntu (64-bit)
Xubuntu (64-bit)
If you would like some help checking 32 bit installs let me know what you haven't checked and I will start on some of whats left.
Tim
What I checked
Mint
Cinnamon (64-bit)
KDE (64-bit)
MATE (64-bit)
Xfce (64-bit)
Ubuntu 14.04.3
Kubuntu (64-bit)
Lubuntu (64-bit)
Xubuntu (64-bit)
Tim
Last edit: 19 Dec 2015 00:39 by tjmarch.
Time to create page: 0.097 seconds
