ubuntu 14.04.1 linuxcnc help
- Razor_keen
- Thank you received: 4
I haven't had much computer time in the last few days. I'm hoping to have time tomorrow afternoon. It's always a little hectic around holidays. I apologize for holding things up on my end. I got as far as burning a disk with mint kde, mate, and cinnamon. I'm hoping I can test these three after work.
I have made a change in the ISO you should re-download ISO again. The change that I made allows for just a sim install if user would like. I have also finished checking all the 32 bit installs. The ISO will work on Ubuntu 14.04.1 or 14.04.2 or 14,04.3 any flavor and Linux Mint 17.1 or 17.2 or 17.3 any flavor. 32-bit or 64-bit Ubuntu and Mint. On a updated OS the install takes about 5 min.
What I checked
Mint
Cinnamon (32-bit) & (64-bit)
KDE (32-bit) & (64-bit)
MATE (32-bit) & (64-bit)
Xfce (32-bit) & (64-bit)
Ubuntu 14.04.3
Ubuntu.desktop (32-bit) & (64-bit)
Ubuntu GNOME (32-bit) & (64-bit)
Kubuntu (32-bit) & (64-bit)
Lubuntu (32-bit) & (64-bit)
Xubuntu (32-bit) & (64-bit)
It is very easy to use LinuxCnc with both Rtai and Rt kernels if installed and switch is done correctly. ISO can be used multiple times without harm just un-install LinuxCnc before using again. I now have to work on the documentation that will be included.
Tim
- Thank you received: 1370
- Razor_keen
I was looking for the .sh file. I glanced for about a minute, but is it similarly titled like in previous .sh files we've experimented with?
The install was very clean, the extra files are now longer present in the home folder.
There was no option if installing both kernels as to which to compile linuxcnc with. Might be an additional thing to consider. The script chose the rtai kernel to compile linuxcnc with.
Im sure you dont mind me making minor tweaks, right?
Sorry ive been a bit scarce. Its typical though, I can never get time to myself when I want it..
If you choose to load both kernels the deb files will be present in home folder. You are correct when both kernels are loaded the script defaults to Rtai for lcnc install. If you want to use the Rt kernel, (takes about 2 min) there is no need to compile
open Terminal and
sudo dpkg -r linuxcnc <will un-install linuxcnc for Rtai kernel
then use gdebi
sudo gdebi -n linuxcnc-uspace_2.7.3_Rt_i386.deb <will install linuxcnc for Rt, need a internet connections the first time you do this
Open Grub-Coustomizer
Now click the "General Setting" tab
Click on choice box to the right of predefined
In drop down menu choose 3.2.0-0.bpo.4-rt-686-pae for default system boot
Making sure you do not choose (recovery mode) option for your kernel
Then reboot
If you want to go back to using Rtai kernel, (takes about 2 min) there is no need to compile
open Terminal and
sudo dpkg -r linuxcnc-uspace <will un-install linuxcnc for Rt kernel
then use gdebi
sudo gdebi -n linuxcnc_2.7.3_rtai_i386.deb <will install linuxcnc for Rtai
In drop down menu choose 3.4-9-rtai-686-pae for default system boot
Then reboot
Tim
PS note this whole process you never compile Linuxcnc even when first load from ISO
So are you guys ready to share a link to your nifty little installation tool yet?
I need to make a short document about installation. Please allow me a little time, I am currently working 10 hours a day with my job 7 days a week. Trying to go as fast as I can.
Tim
I do not think anything needs to be changed with install process please read on farther. I know we talked about adding a file about latency which can be done at a anytime because we are still in control of content of ISO
I have made a install_note.txt , if txt file makes sense to you I was thinking of making ISO available
Contents of txt file are
To best use this file view in a basic text editor
in full screen
such as
gedit or mousepad or pluma
a word processor will line wrap and trying to copy and paste is faulty
To use ISO for install of Linuxcnc 2.7.3 on a pre-installed updated OS
only works on
Cinnamon (32-bit) or (64-bit)
KDE (32-bit) or (64-bit)
MATE (32-bit) or (64-bit)
Xfce (32-bit) or (64-bit)
Ubuntu.desktop (32-bit) or (64-bit)
Ubuntu GNOME (32-bit) or (64-bit)
Kubuntu (32-bit) or (64-bit)
Lubuntu (32-bit) or (64-bit)
Xubuntu (32-bit) or (64-bit)
Edubuntu (32-bit) or (64-bit)
32-bit kernels available
3.2.0-0.bpo.4-rt-686-pae <Rt-preempt - source Debian Squeeze repository
3.4-9-rtai-686-pae <Rtai- source Linuxcnc repository
64-bit kernel available
3.2.0-0.bpo.4-rt-amd64 <Rt-preempt - source Debian Squeeze repository
Place lcncInstall.iso in home directory then
open terminal
sudo su -
mkdir -p /mnt/disk;mount -o loop /home/`who | cut -d' ' -f1 | sort | uniq`/lcncInstall.iso /mnt/disk;/mnt/disk/install.sh;umount /mnt/disk -l
Follow direction displayed in Terminal
If you choose to install Sim only 32-bit or 64-bit, sim install dose not install a new kernel
but now you want to install realtime kernel or kernels
open Terminal
sudo dpkg -r linuxcnc-uspace <will un-install linuxcnc for Sim
Then need to use ISO again
sudo su -
NOTE: for sim install no reboot is required, but menu items will most likely be in category Other
after you you log out of system then back in or a reboot menu items will then be in CNC
The script defaults to Rtai for install of Linuxcnc if both kernels are installed.
open Terminal and
then use gdebi
Find Grub-Coustomizer in start menu
Then reboot
open Terminal and
then use gdebi
NOTE you will see a error it is not a problem linuxcnc is not happy with the current booted kernel
Then reboot
If you only choose to install one 32-bit kernel but now what to install the other
You must install both kernels , deb files will only be available in home directory if you choose to install both kernels
Re-install of kernel that is already installed will not hurt anything.
But first you need to un-install Linuxcnc
To un-install Linuxcnc on Rtai
open Terminal
or
open Terminal
Then if booted into Rtai or Rt kernel
use of ISO is a little different
sudo su -
modprobe loop
NOTE
If you installed Linuxcnc for Rt kernel you can run linuxcnc booted into a generic or Rtai kernel in sim mode only
With Rtai install if not in Rtai kernel and trying to run linuxcnc you will get error message on screen
It is always good to check what kernel you are booted into to do this
open Terminal
uname -r
Another good check for Linuxcnc Rt kernel install
start linuxcnc from Terminal
open Terminal
linuxcnc
Choose and run a configuration
if you are in sim only mode you will see in Terminal
Note: Using POSIX non-realtime
if you are booted into Rt kernel you will see in Terminal
Note: Using POSIX realtime
Tim
I have to update ISO to include this txt file
I also will start working on latency doc I will most likely make it a pdf
Tim
To all concerned I have made a request to Canonical to make this ISO public on the Linuxcnc.org web site this was my request.
I have made a ISO to install Linuxcnc software it contains Deb files that I created and packages downloaded from Canonical IP to be used on a pre-installed operating system of Ubuntu 14.04 or Linux Mint 17. The install process of Linuxcnc only will take about 5 minutes. The ISO image must be mounted then a script file is run to install the needed packages that are contained in the image. If any packages that are still needed for the install due to flavor differences will download from Canonical Trusty repo. I am requesting permission to make this ISO public and for no personal gain on the Linuxcnc.org web site. ISO image will be free of charge and no gain for Linuxcnc.org.
Tim March
- Razor_keen
I really wished I had more time to help. I'm seeing your post from my phone and if no one else says it, thank you.
Sorry I meant no offense by asking a change in the setup, I just meant some may have a preference, and may opt for both kernels for experimental purposes. Your instructions are very claer, however, that it may not matter.
I wished timing was better, again I apologize.
