ubuntu 14.04.1 linuxcnc help
03 Dec 2015 03:44 #66268
by tjmarch
Replied by tjmarch on topic ubuntu 14.04.1 linuxcnc help
try here for joy stick
wiki.linuxcnc.org/cgi-bin/wiki.pl?Using_X11_Joystick_Driver
also allot of good info here some out dated
There is also some youtube videos on subject of joy sick with linuxcnc
- Razor_keen
- Thank you received: 4
03 Dec 2015 03:45 #66269
by Razor_keen
Replied by Razor_keen on topic ubuntu 14.04.1 linuxcnc help
Right on. i think i've seen it done with a playstation 2 controller as well. Ill look it up. I have quite a few controllers around the house. It would be good to make use of one of them.
- Razor_keen
03 Dec 2015 04:19 #66270
by Razor_keen
I dont know if your familiar with using an rc motor to make a spindle but its a pretty effective method, granted you need a pretty goodd power supply to run it. server power supplies are cheap, fortunatly. There are several examples in the rc group forums.
03 Dec 2015 06:17 #66272
by Rick G
wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple_Remote_Pendant
wiki.linuxcnc.org/cgi-bin/wiki.pl?Adding...imple_Remote_Pendant
wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNCKnowledgeBase
Rick G
Replied by Rick G on topic ubuntu 14.04.1 linuxcnc help
Rick G
The following user(s) said Thank You: Razor_keen
03 Dec 2015 16:26 #66288
A curious thing lives in the LinuxCNC code:
github.com/jepler/linuxcnc-mirror/blob/c.../scripts/teach-in.py
Replied by andypugh on topic ubuntu 14.04.1 linuxcnc help
I can see why you would want the pendent to teach robot arms with manual gcode entry which will be a tough way to go but I do not know of another way for robot path to be entered using linuxcnc.
The following user(s) said Thank You: tjmarch
- Razor_keen
04 Dec 2015 03:17 - 04 Dec 2015 03:32 #66349
by Razor_keen
do you think installing a lighter system such as mint would improve latency? im not sure exactly where the bottleneck is in thiscomputer so limiting throughput may help?
Again i was wondering if anyone had reduced latency by increasing ram or cpu.
thanks
jason
thanks
jason
Last edit: 04 Dec 2015 03:32 by Razor_keen.
- Razor_keen
06 Dec 2015 10:05 #66500
by Razor_keen
I am sad to report back, i have tried linux mint 17 and despite the many latency reducing techniques i used with ubuntu, latency is very high on this os. I would have thought it would have been slightly better because of the lighter de. thats all for now
06 Dec 2015 13:22 #66506
by BigJohnT
Replied by BigJohnT on topic ubuntu 14.04.1 linuxcnc help
I have one old PC that had bad latency with Ubuntu 10.04, worse with Debian Wheezy and even worse with LinuxMint. I don't use that PC for real time anything.
JT
JT
- Razor_keen
06 Dec 2015 19:37 - 07 Dec 2015 00:21 #66519
by Razor_keen
The way i got the latency down was by following the instructions here.
forum.linuxcnc.org/forum/18-computer/259...-pcs-success?start=6
I had the latency values down to `8000 and ~12000, but itried to reinstall ubuntu and follow these instructions to replicate it, but failed. i think i may have made a chang to the file titles? like add .sh? im not sure how these files change things at boot uo, but can someone confirm they are going to the right places? I was really excited to have had such good latency on a laptop, but i should have been documenting everything i was doing.
Last edit: 07 Dec 2015 00:21 by Razor_keen.
06 Dec 2015 21:44 - 07 Dec 2015 07:57 #66528
by tjmarch
Razor_keen
I was thinking of using Rt-preempt 64 bit kernel myself latancy looked promising but so dose Rtai 32 bit install
been playing with both. I am also using a Intel dual core processor which was getting bad latancy spikes, the following procedures got rid of the spikes. The best latancy-test results I achieved were:
Latency Rtai kernel 32 bit system
needs to be re-reviewed
Latency Rt-preempt kernel 64 bit system
33273 us
33.273 ms
Also when adding idle=poll to what I show to add in todolist doubled latancy-test results for me
I have attached the files for you to view everything I did on 32bit and 64bit systems
Maybe something is listed that you have not tried, or you could try 32 bit install
When using Menu->CNC->LinuxCNC then Configuration Selector->apps->latency-plot
On 64 bit system I get a couple of spikes when latency-plot starts but after that it is stays low, accept when moving large folders full of files on hard drive:this has been resolved with edited todolist
Looks like I should not write to hard drive while machine will be running or check into a solid state drive: this has been resolved with edited todolist
Tim
Attached files edited 12/06/2015 11:55pm central
33273 us
33.273 ms
Tim
Last edit: 07 Dec 2015 07:57 by tjmarch.
Time to create page: 0.203 seconds
