Upgraded to 2.7.13 -- W T F --
08 Jul 2018 15:26 #113813
by tecno
Replied by tecno on topic Upgraded to 2.7.13 -- W T F --
Did it the "wrong" way and edited grub.cfg and did not do update-grub. Everything is now running OK as it looks and I can't replicate earlier freeze conditions. The result should be the same, right?
08 Jul 2018 15:49 #113816
Replied by PCW on topic Upgraded to 2.7.13 -- W T F --
You can do this but it will eventually bite you as some other operations run update-grub
08 Jul 2018 15:52 #113818
by tecno
I stand corrected and will fix this
09 Jul 2018 12:27 #113867
by tecno
I GIVE UP WITH THIS NUC
Those FREEZE situations comes even now without any graphics intense loaded.
Time to order another GigaByte BRIX j1900
09 Jul 2018 14:45 #113878
Replied by rodw on topic Upgraded to 2.7.13 -- W T F --
I use a Gigabyte Brix J1900 and have also used a Brix N3160 with my 7i76e. Just pull the wifi card out of it so you are never tempted to get it going.
Also the ISOLCPU's is very much a red herring in my experience as PCW has stated. Don't even think about configuring it.
I did do a lot of tests disabling the BIOS settings before deciding on the best config to use.
09 Jul 2018 15:59 #113880
by tecno
Hi Rod,
Yes I have one up and running in my mill, works just fine. will get my order delivered next Monday (my birthday ) so then I will have new toy to play with. Will clone the HDD I have so it will be up and running in no-time.
Time to create page: 0.440 seconds
