Upgraded to 2.7.13 -- W T F --
07 Jun 2018 17:26 #111903
by tecno
Upgraded to 2.7.13 -- W T F -- was created by tecno
07 Jun 2018 17:47 #111906
Replied by PCW on topic Upgraded to 2.7.13 -- W T F --
sounds like you accidentally "upgraded" your OS also
what does
uname -a
print?
what does
uname -a
print?
07 Jun 2018 17:49 #111909
by tecno
Replied by tecno on topic Upgraded to 2.7.13 -- W T F --
Will get back on this asap.
First update then dist-upgrade, is that wrong way to do it?
07 Jun 2018 18:05 #111914
by tecno
07 Jun 2018 18:07 #111915
by tecno
Mill appears to work as usual, just tested some axis movement + spindle and homing.
07 Jun 2018 18:16 #111917
by tecno
07 Jun 2018 18:34 #111918
OK so that's the correct kernel so maybe the LinuxCNC is not the uspace version (so its running in non-realtime=simulation mode)
07 Jun 2018 18:41 #111920
by tecno
Hmmm, just started my normal INI = CNC3000.ini
But unsure as normally I do not have any text in the right panel ( as I recall ) and now there is a lot of text with LatheMacros etc...
Will have to investigate more tomorrow.
Will be without LAN some days as I have to return faulty product for replacement.
So there is nothing I need to do via LAN just now then?
07 Jun 2018 18:50 #111921
What does linuxcnc print when you start it?
(the first few lines)
07 Jun 2018 19:24 #111924
by tecno
Report tomorrow, it is close to bedtime here
Time to create page: 1.296 seconds
