Upgraded to 2.7.13 -- W T F --
15 Jun 2018 18:57 #112429
by tecno
Replied by tecno on topic Upgraded to 2.7.13 -- W T F --
When I get so far as to update grub >>>> i915.enable_rc6=0 does not exist.
15 Jun 2018 19:13 #112430
by tecno
I give up with Debian on this PC.
Will reinstall Mint 18.3 and try to install RT and LinuxCNC
- InMyDarkestHour
- User is blocked
- Thank you received: 111
17 Jun 2018 23:29 #112515
by InMyDarkestHour
Replied by InMyDarkestHour on topic Upgraded to 2.7.13 -- W T F --
Found some info on installing Debian Stretch on your little PC.
forums.debian.net/viewtopic.php?f=17&t=127662
wiki.debian.org/InstallingDebianOn/Intel/NUC5PPYH
Update BIOS to version 50
Set BIOS boot configuration to "Linux" (necessary for newer kernels)
Install Debian netinst image and nonfree firmware
A great bit of info from JT about install fron the netinst cd.
Ignore the first line regarding the Wheezy install and precede with the Debian 9 instructions. Which covers the Recommendation to in the 2 above links to Install Debian netinst image and nonfree firmware
mesaus.com/info/debian-9-uspace.txt
18 Jun 2018 06:35 - 18 Jun 2018 07:05 #112520
by tecno
My BIOS is version 54
downloadmirror.intel.com/26220/eng/PY_0055_ReleaseNotes.pdf
Have boot set to Linux
Will follow the Debian net install and see what happens.
Later...
Later...
Last edit: 18 Jun 2018 07:05 by tecno.
18 Jun 2018 07:28 #112521
by tecno
OK done that and the first I run is latency-histogram --nobase >>> FREEZING!
- InMyDarkestHour
- User is blocked
18 Jun 2018 07:55 #112522
by InMyDarkestHour
So it's boots ok and the graphics is good.
Running the debian rt kernel ok, apart from the latency-histogram ?
Linuxcnc was installed as per JT's instructions, should be version 2.7.13 ?
Before you run the latency-histogram run [(may have to use su or sudo)
That will display the messages and then start with an empty buffer so anything new wont be lost in a 1000 other messages.
Have you tried
When you go to close the latency-histogram window it does close ?
Is there anything in dmesg that looks odd ?
dmesg -c
Have you tried
latency-histogram --nobase --verbose
18 Jun 2018 08:01 #112523
by tecno
Did manage to get grub.cfg edited with isolcpus=2,3 before freezing again.
Did manage to get Axis to run and Gmoccapy after reboot
Now running latency test with 6 GLX gears
Will take a short brake and get my morning shower now that my water is heated up
So far so good, will do more extensive test during the day.
18 Jun 2018 08:32 #112524
by tecno
Nothing in dmesg and yes window closes OK
Before you run the latency-histogram run [(may have to use su or sudo)dmesg -c
Have you triedlatency-histogram --nobase --verbose
18 Jun 2018 08:38 #112526
by tecno
Now running Axis sim demo and it looks OK
18 Jun 2018 10:26 #112528
by tecno
Now running my old HDD with edit grub.cfg = added isolcpus=2,3 and no more hanging as it looks now anyways, still testing PC here in office before I go down to my Lathe.
4.9.0-6-rt-686-pae # SMP PREEMPT RT Debian 4.9.88-1+deb9u1 (2018-05-07) i686
Time to create page: 0.259 seconds
