Installing LinuxCNC on Debian 9
10 Jul 2018 18:00 - 07 Feb 2019 15:36 #113960
by BigJohnT
Installing LinuxCNC on Debian 9 was created by BigJohnT
Here is the method I use to install LinuxCNC on Debian 9 and setup for using an Ethernet Mesa card.
gnipsel.com/linuxcnc/uspace/debian9-rt.html
gnipsel.com/linuxcnc/uspace/debian9-emc.html
gnipsel.com/linuxcnc/uspace/debian9-eth.html
I've gathered all my instructions into one place for Uspace and various OS's
JT
JT
Last edit: 07 Feb 2019 15:36 by BigJohnT.
The following user(s) said Thank You: trilobyte, tommylight, InMyDarkestHour, rodw, ikkuh, Grotius, spma, JetForMe
11 Jul 2018 19:56 #114024
by Grotius
Replied by Grotius on topic Installing LinuxCNC on Debian 9
Hi John,
Why not cloning a pre configured debian 9 with clonezilla server? clonezilla.org/clonezilla-SE
This saves time.... I only tried the cd clonezilla, this works perfect. 15 minutes ready.
Is this an idea to use?
11 Jul 2018 22:20 #114035
by BigJohnT
Replied by BigJohnT on topic Installing LinuxCNC on Debian 9
I guess once you setup the drive cloning it might be a good thing.
JT
JT
- Thank you received: 5973
12 Jul 2018 05:20 #114044
Replied by tommylight on topic Installing LinuxCNC on Debian 9
Or use "SystemBack" that is very friendly and easy to use.
In some cases you have to uninstall casper and install liveboot, but otherwise it works nicely and can also make an ISO that can be booted from a USB.
04 Aug 2018 02:00 #115574
by Vitran
Replied by Vitran on topic Installing LinuxCNC on Debian 9
cdimage.debian.org/cdimage/unofficial/no....0-amd64-netinst.iso
This link you provided is only a few days old, but it is giving a 404 Not Found. Where can one find where the disk images are?
- InMyDarkestHour
- User is blocked
- Thank you received: 111
04 Aug 2018 07:45 #115593
by InMyDarkestHour
Replied by InMyDarkestHour on topic Installing LinuxCNC on Debian 9
04 Aug 2018 12:31 #115599
by Vitran
That works, thank you. Yesterday it was providing a 404 when I copied BigJohnT's link no matter what I tried, but I was doing it on a different computer.
04 Aug 2018 15:10 #115605
by BigJohnT
I should have known better than to put the file name in the link... it will change.
JT
JT
01 Oct 2018 11:40 #118278
by sirx
Replied by sirx on topic Installing LinuxCNC on Debian 9
Hi admin,
please it's all right until I type this line:
lablpm@PCBCNC2:~$ sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key 3cb9fd148f374fef
Executing: gpg --ignore-time-conflict --no-options --no-default-keyring --secret-keyring /tmp/tmp.V8ERg2YaYv --trustdb-name /etc/apt//trustdb.gpg --keyring /etc/apt/trusted.gpg --primary-keyring /etc/apt/trusted.gpg --keyring /etc/apt/trusted.gpg.d//debian-archive-jessie-automatic.gpg --keyring /etc/apt/trusted.gpg.d//debian-archive-jessie-security-automatic.gpg --keyring /etc/apt/trusted.gpg.d//debian-archive-jessie-stable.gpg --keyring /etc/apt/trusted.gpg.d//debian-archive-squeeze-automatic.gpg --keyring /etc/apt/trusted.gpg.d//debian-archive-squeeze-stable.gpg --keyring /etc/apt/trusted.gpg.d//debian-archive-wheezy-automatic.gpg --keyring /etc/apt/trusted.gpg.d//debian-archive-wheezy-stable.gpg --keyserver hkp://keys.gnupg.net --recv-key 3cb9fd148f374fef
gpg: requesting key 8F374FEF from hkp server keys.gnupg.net
?: keys.gnupg.net: Host not found
gpgkeys: HTTP fetch error 7: couldn't connect: No such file or directory
gpg: Non sono stati trovati dati OpenPGP validi.
gpg: Numero totale esaminato: 0
lablpm@PCBCNC2:~$
Please help me to fix the problem
best regards
sirx
lablpm@PCBCNC2:~$
best regards
sirx
21 Oct 2018 15:16 #119161
by BigJohnT
You probably skipped a step.
JT
JT
Time to create page: 0.269 seconds
