Installing LinuxCNC on Debian 9
- DaveInConesus
03 Jan 2019 21:53 #123433
by DaveInConesus
Replied by DaveInConesus on topic Installing LinuxCNC on Debian 9
I got it in the case and found an old parallel port card in my box of junk. A couple insertions to clean the contacts and linux is seeing the port. I had also installed the Radeon drivers to get rid of an error message on startup. That added about 30k ns to my jitter so I took it back off. Slightly uglier graphics are fine with me.
I am thinking that I will order a cheap $20 BOB/cable combo and get things going. I can move to a Mesa board later on if I need it.
15 Mar 2019 14:38 #128659
by sidkan
Replied by sidkan on topic Installing LinuxCNC on Debian 9
I would like to know how did you install the Nvidia drivers on preempt-RT kernel and which Nvidia driver was used?
- DaveInConesus
15 Mar 2019 15:07 #128663
by DaveInConesus
At this point I don't remember how I did it. I probably just ticked the box to allow proprietary drivers to install and then searched for radeon in the software list.
- Thank you received: 5972
15 Mar 2019 17:45 #128674
Replied by tommylight on topic Installing LinuxCNC on Debian 9
You are not talking about the same thing.
And there are no Radeon drives in the driver manager in Linux, only Nvidia.
Radeon drives have to be downloaded from the AMD website.
Nvidia can be made to work with Preempt-RT in some cases, not always. AMD is much harder to make work.
Did not try the RTAI version.
Time to create page: 0.066 seconds
