A well-functioning configuration for ChinaCNCzone 3040Z-DQ
17 Sep 2018 17:33 #117662
by ogogon
A well-functioning configuration for ChinaCNCzone 3040Z-DQ was created by ogogon
- Thank you received: 5942
17 Sep 2018 19:23 #117664
Replied by tommylight on topic A well-functioning configuration for ChinaCNCzone 3040Z-DQ
That is easy, just pick one of the administrators or moderators of this forum, send him or her a machine for free or for a limited period of time, and many will get you a working config for version 2.7 and 2.8.
Or you can ask us how to configure it yourself and we will gladly help.
If anyone already has a working config they will post it for sure.
17 Sep 2018 20:19 #117669
by ogogon
Ogogon.
Replied by ogogon on topic A well-functioning configuration for ChinaCNCzone 3040Z-DQ
Thank you, this is a very interesting way. Unfortunately, the transfer of the CNC machine and the control computer will cost me more than the machine itself and the computer.That is easy, just pick one of the administrators or moderators of this forum, send him or her a machine for free or for a limited period of time, and many will get you a working config for version 2.7 and 2.8.
This is more real for me. Moreover, I already had to install EMC2 several times before. But now, I have obviously run into some kind of underwater rock. I am ready to do this.Or you can ask us how to configure it yourself and we will gladly help.
It will be wonderful! If such work is already done - why do it again?If anyone already has a working config they will post it for sure.
Ogogon.
17 Sep 2018 20:39 #117671
You learn something new.It will be wonderful! If such work is already done - why do it again?
Ogogon.
17 Sep 2018 20:59 - 17 Sep 2018 21:08 #117673
by ogogon
With all due respect to the efforts and resources invested in the EMC2/LCNC, I consider it a temporary and transitional solution.
I believe that it will be replaced by a qualitatively different one, built on a platform with a hard real-time, and most likely - an embedded platform.
From the EMC2/LCNC will remain a visualization subsystem and elements of KAD/CAM. Perhaps, there will still be a system of interaction with the HID periphery.
Ogogon.
Maybe you are right, but I have some academic doubts ...You learn something new.
Ogogon.
Last edit: 17 Sep 2018 21:08 by ogogon.
17 Sep 2018 21:49 #117675
by Grotius
Replied by Grotius on topic A well-functioning configuration for ChinaCNCzone 3040Z-DQ
Hi Ogo,
This product has standard a embedded cnc controller.
It is a lot of work to modify this product. Better buy something else.
18 Sep 2018 00:00 #117683
by ogogon
What product are you talking about? Which controller does not make sense to modify?
Did I miss something?
Ogogon.
I'm sorry, but I did not understand what you mean?Hi Ogo,
Ogogon.
18 Sep 2018 00:09 - 18 Sep 2018 00:11 #117684
Replied by PCW on topic A well-functioning configuration for ChinaCNCzone 3040Z-DQ
Actually its not clear what you have, some 3040Z-DQ's come with USB motion controllers and some are parallel port compatible. A parallel port model would work directly with LinuxCNC.
The USB model would not work without some modification (removing the USB motion interface at a minimum perhaps re-wiring the USB interface to the drives/limit switches if its not brought out to a parallel port pinout at some point)
Last edit: 18 Sep 2018 00:11 by PCW.
18 Sep 2018 00:47 #117685
by ogogon
Strict, conservative LPT-port. Photo attached.
Ogogon.
P.S. The goat is wonderful!!
Ogo,
My control station - without any signs of USB.Actually its not clear what you have, some 3040Z-DQ's come with USB motion controllers and some are parallel port compatible. A parallel port model would work directly with LinuxCNC.
Ogogon.
Ogo,
- Thank you received: 1369
18 Sep 2018 01:24 #117686
Replied by Todd Zuercher on topic A well-functioning configuration for ChinaCNCzone 3040Z-DQ
Did the manufacturer or seller supply you with a Mach3 configuration file? If you happen to have that xml file Stepconfig in Linuxcnc can import it to help build a linuxcnc config.
Time to create page: 0.107 seconds
