lost boy mesanet 7i76e
05 Jan 2019 01:21 #123526
by Heamam
lost boy mesanet 7i76e was created by Heamam
Hello everyone, a new user is introduced.
buy a 7i76e mesante and install linuxcnc uspace from here:
www.linuxcnc.org/testing-stretch-rtpreempt/
this version:
www.linuxcnc.org/testing-stretch-rtpreem...tch-uspace-amd64.iso
PC Laptop lenovo T430s i5 8GB Ram
Is it necessary for me to make any more modifications or with this installation I already have all the necessary things that work?
Thank you very much for the answers
this version:
- Thank you received: 5972
05 Jan 2019 22:04 #123568
Replied by tommylight on topic lost boy mesanet 7i76e
That is all you need for it to work and a lot of reading.
Get the Mesa 7i76E manual from the mesanet web site, read the parts pertaining to power supply for the logic and the field part, the network setup part and the wiring and connections part.
Basically you have to set the network on your laptop to manual and give it an IP address of 10.10.10.11, gateway of 10.10.10.1, DNS 10.10.10.1, save and reconnect. On the mesa board there are jumpers to set the board IP to 10.10.10.10.
Open a terminal and type
ping 10.10.10.10
you should get a reply, and you are ready to use the board, after you make a config for it, or just search the forum, there are some ready made configs that might work for you.
ping 10.10.10.10
06 Jan 2019 21:07 #123642
by newbynobi
Replied by newbynobi on topic lost boy mesanet 7i76e
I made a howto connect that card and posted if here in the forum in the driver card section.
From my fone i can not search for it, but you should.
Norbert
Norbert
06 Jan 2019 23:55 #123655
by Heamam
Replied by Heamam on topic lost boy mesanet 7i76e
thanks for the reply, I read a few interesting articles in the forum, but maybe this forum is so extensive that you can lose.
07 Jan 2019 07:13 #123675
Replied by rodw on topic lost boy mesanet 7i76e
Norbert's amazing connection sheet is here
forum.linuxcnc.org/27-driver-boards/3191...ection-sheet?start=0
Also under the Hal examples, there is an example 7i76e config I put together for master branch. It is probably not 100% correct now with the change to multi spindle support.
Time to create page: 0.069 seconds
