Debian Stretch Tricks, Info & Resources
- InMyDarkestHour
- Topic Author
- User is blocked
- Thank you received: 111
02 Apr 2019 09:15 - 02 Apr 2019 09:22 #130148
by InMyDarkestHour
Debian Stretch Tricks, Info & Resources was created by InMyDarkestHour
Some of the tricks and info I've picked up when working with Stretch
Boot into Text Mode
To temporarily boot into text mode, edit the kernel command line in grub and add
In order to make text boot the default under systemd (regardless of which distro, really)
To change back to booting to the GUI
Boot into Text Mode
systemd.unit=multi-user.target
systemctl set-default multi-user.target
systemctl set-default graphical.target
Last edit: 02 Apr 2019 09:22 by InMyDarkestHour.
The following user(s) said Thank You: Mike_Eitel, chimeno
17 Apr 2019 15:25 #131055
by pl7i92
Replied by pl7i92 on topic Debian Stretch Tricks, Info & Resources
what will be the benefit to get this mode
- Thank you received: 5974
17 Apr 2019 16:57 #131059
Replied by tommylight on topic Debian Stretch Tricks, Info & Resources
In case of a messed up system, that is very handy to fix things.
Text mode or CLI rules in the Linux world.
- InMyDarkestHour
- Topic Author
- User is blocked
17 Apr 2019 19:56 #131073
by InMyDarkestHour
Replied by InMyDarkestHour on topic Debian Stretch Tricks, Info & Resources
There is no “benefit” but sometimes to fix a messed up Desktop confit or to hand edit a desktop config it’s easier to do ,or the only way, without X running. Xconf doesn’t play nicely when hand editing config files.
Or you may need to transfer Desktop setting and menus from one machine to another.
Plus many other reasons you may want to do some admin with a pure terminal without X.
18 Apr 2019 07:36 #131116
Servers!
No desktop, just a nice black abundance of pure nothingness, with a lot going on behind the scenes !
- InMyDarkestHour
- Topic Author
- User is blocked
18 Apr 2019 10:08 #131141
by InMyDarkestHour
Real servers run Slackware
Where Real Men lurk
And dependency hell is just exploring
Installing Gitlab was fun.
I get 1 hour in the sunshine everyday under the close eye of the pretty nurses now.
Then just for fun Linuxcnc installed after building a system using Linux From Scratch and Beyond Linux From Scratch.
Where Real Men lurk
19 Apr 2019 16:08 #131242
Jacket ?Installing Gitlab was fun.
- InMyDarkestHour
- Topic Author
- User is blocked
20 Apr 2019 02:58 #131269
by InMyDarkestHour
With big bright shiny buckles for the first six months
20 Apr 2019 14:37 #131308
LOL
Time to create page: 2.269 seconds
