Installing LAN on new Linux CNC install
- Type_Zero_Design
- Thank you received: 7
22 Apr 2019 22:11 #131560
by Type_Zero_Design
Installing LAN on new Linux CNC install was created by Type_Zero_Design
Hey Everyone,
I am having trouble getting my Ethernet ports working on my gigabyte GA-H87N Mother Board.
I have succesfully installed Linux from the most current Linux CNC download, but was unable to install my ethernet ports.
The board has Dual Ethernet Ports, and the Idea was to use one as a wired network connection and one as the connection for my 7i76e
If anyone can give some advise on where to go to get this working it would be greatly appreciated as I have zero linux experience.
Thanks!
Thanks!
22 Apr 2019 22:54 #131563
Replied by PCW on topic Installing LAN on new Linux CNC install
Pretty sure Wheezy will not work with the Intel MACs on the GA-H87N
Did you try Stretch?
www.linuxcnc.org/testing-stretch-rtpreempt/
- Type_Zero_Design
22 Apr 2019 22:58 #131564
by Type_Zero_Design
Replied by Type_Zero_Design on topic Installing LAN on new Linux CNC install
I have not...
Is stretch another version of Linux?
- Type_Zero_Design
22 Apr 2019 23:00 #131565
by Type_Zero_Design
Also what is MAC
22 Apr 2019 23:05 - 22 Apr 2019 23:06 #131567
Yes:
Debian versions:
Wheezy = 7 (obsolete) released 2013
Jessie = 8 (obsolete) released 2015
Stretch = 9 (current) released 2017
Buster = 10 (probable mid year release)
MAC is Media Access Controller = Ethernet chip basically
Debian versions:
Last edit: 22 Apr 2019 23:06 by PCW.
- Type_Zero_Design
22 Apr 2019 23:09 #131569
by Type_Zero_Design
Ok, I see. I apologise for my ignorance in regards to Linux. So with that being said the Linux CNC download from the sight uses wheezy, which I installed. Is there a way to simply upgarde or do I just install a whole new version fresh?
- InMyDarkestHour
- User is blocked
- Thank you received: 111
22 Apr 2019 23:34 #131572
by InMyDarkestHour
Replied by InMyDarkestHour on topic Installing LAN on new Linux CNC install
Before you go ahead and re install can you try
And copy the output......I'll check if stretch supports your ethernet chips.
sudo lspci
- Type_Zero_Design
22 Apr 2019 23:44 - 22 Apr 2019 23:45 #131573
by Type_Zero_Design
Mutt,
This is what I got back:
00:00.0 Host bridge: Intel Corporation Haswell DRAM Controller (rev 06)
00:02.0 VGA compatible controller: Intel Corporation Device 041e (rev 06)
00:03.0 Audio device: Intel Corporation Haswell HD Audio Controller (rev 06)
00:14.0 USB controller: Intel Corporation Lynx Point USB xHCI Host Controller (rev 05)
00:16.0 Communication controller: Intel Corporation Lynx Point MEI Controller #1 (rev 04)
00:16.3 Serial controller: Intel Corporation Lynx Point KT Controller (rev 04)
00:19.0 Ethernet controller: Intel Corporation Ethernet Connection I217-V (rev 05)
00:1a.0 USB controller: Intel Corporation Lynx Point USB Enhanced Host Controller #2 (rev 05)
00:1b.0 Audio device: Intel Corporation Lynx Point High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation Lynx Point PCI Express Root Port #1 (rev d5)
00:1c.3 PCI bridge: Intel Corporation Lynx Point PCI Express Root Port #4 (rev d5)
00:1d.0 USB controller: Intel Corporation Lynx Point USB Enhanced Host Controller #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation Lynx Point LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation Lynx Point 6-port SATA Controller 1 [AHCI mode] (rev 05)
00:1f.3 SMBus: Intel Corporation Lynx Point SMBus Controller (rev 05)
02:00.0 Ethernet controller: Atheros Communications Inc. AR8161 Gigabit Ethernet (rev 10)
After doing some googling on stretch and linux cnc, it seems like the official release hasnt been pushed out yet reading the Gethub. I did find a live image here: linuxcnc.org/testing-stretch-rtpreempt/ Though im not exactly sure how to use whats on this page....
After reading through more on git hub that looks like the direction I will have to go one way or the other because of the ethernet conection on the 7i76e?
This is a lot to take in so I may be mis interpretting what i was reading there.
Last edit: 22 Apr 2019 23:45 by Type_Zero_Design.
- InMyDarkestHour
- User is blocked
23 Apr 2019 00:07 #131577
by InMyDarkestHour
Sorry it should have been
I have a feeling that your ethernet controller may not be supported in stretch, if it isn't and it is the device i think it is I have posted a solution before.
sudo lspci -nn
- Type_Zero_Design
23 Apr 2019 00:24 #131579
by Type_Zero_Design
Mutt,
Heres the update:
daniel@BrotherTC-225:~$ sudo lspci -nn
[sudo] password for daniel:
00:00.0 Host bridge [0600]: Intel Corporation Haswell DRAM Controller [8086:0c00] (rev 06)
00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:041e] (rev 06)
00:03.0 Audio device [0403]: Intel Corporation Haswell HD Audio Controller [8086:0c0c] (rev 06)
00:14.0 USB controller [0c03]: Intel Corporation Lynx Point USB xHCI Host Controller [8086:8c31] (rev 05)
00:16.0 Communication controller [0780]: Intel Corporation Lynx Point MEI Controller #1 [8086:8c3a] (rev 04)
00:16.3 Serial controller [0700]: Intel Corporation Lynx Point KT Controller [8086:8c3d] (rev 04)
00:19.0 Ethernet controller [0200]: Intel Corporation Ethernet Connection I217-V [8086:153b] (rev 05)
00:1a.0 USB controller [0c03]: Intel Corporation Lynx Point USB Enhanced Host Controller #2 [8086:8c2d] (rev 05)
00:1b.0 Audio device [0403]: Intel Corporation Lynx Point High Definition Audio Controller [8086:8c20] (rev 05)
00:1c.0 PCI bridge [0604]: Intel Corporation Lynx Point PCI Express Root Port #1 [8086:8c10] (rev d5)
00:1c.3 PCI bridge [0604]: Intel Corporation Lynx Point PCI Express Root Port #4 [8086:8c16] (rev d5)
00:1d.0 USB controller [0c03]: Intel Corporation Lynx Point USB Enhanced Host Controller #1 [8086:8c26] (rev 05)
00:1f.0 ISA bridge [0601]: Intel Corporation Lynx Point LPC Controller [8086:8c4a] (rev 05)
00:1f.2 SATA controller [0106]: Intel Corporation Lynx Point 6-port SATA Controller 1 [AHCI mode] [8086:8c02] (rev 05)
00:1f.3 SMBus [0c05]: Intel Corporation Lynx Point SMBus Controller [8086:8c22] (rev 05)
02:00.0 Ethernet controller [0200]: Atheros Communications Inc. AR8161 Gigabit Ethernet [1969:1091] (rev 10)
Heres the update:
