Installing LAN on new Linux CNC install
- Thank you received: 5972
23 Apr 2019 00:51 #131581
Replied by tommylight on topic Installing LAN on new Linux CNC install
It has two ethernet cards, one is Intel, the other is Atheros. Hmmmm i used Atheros a lot back when wardriving was a thing.
Stretch should work with at least one of them, but there are no guaranties.
That seems to be quite new PC, did you check the magnificent tutorials on how to install Linuxcnc on Linux Mint? Linux mint will most probably work with both cards, but it is a bit of a "copy/paste" affair .
I am aware i am not helping much, but i have plenty of computers and i do install them very often, and since i use Linux Mint with Mate desktop i never have such issues. On older computers i use Debian stretch net install and add only what i need at that instance, but i did notice it is a bit on the "picky" side when it comes to ethernet.
- InMyDarkestHour
- User is blocked
- Thank you received: 111
23 Apr 2019 00:51 #131582
by InMyDarkestHour
Replied by InMyDarkestHour on topic Installing LAN on new Linux CNC install
Ok you should be ok with your Intel Ethernet controller and your Atheros Controller should be ok as well.
Download this image:
linuxcnc.org/testing-stretch-rtpreempt/l...uspace-amd64-r12.iso
And use the instructions as before to put this image on a USB stick.
The following user(s) said Thank You: Type_Zero_Design
- Type_Zero_Design
- Thank you received: 7
23 Apr 2019 01:34 #131588
by Type_Zero_Design
Replied by Type_Zero_Design on topic Installing LAN on new Linux CNC install
Tommy,
The PC is actually about 5 years old. I haven't seen/heard of mint but I'll look into it. I didn't buy this PC with the intention of doing Linux, I originally planned to do mach.
- Type_Zero_Design
23 Apr 2019 01:40 #131589
by Type_Zero_Design
Mutt, I see this says AMD is that in reference to the processor? Im running an intel if that makes any diffrence?
- InMyDarkestHour
- User is blocked
23 Apr 2019 02:04 #131590
by InMyDarkestHour
You'll be right with that iso.
I checked with my stretch install and the drivers you need, e1000e for the Intel card and alx for the atheros card.
I ran modinfo on both drivers and the drivers were compiled to load for those particular cards.
- Type_Zero_Design
23 Apr 2019 02:33 - 23 Apr 2019 02:43 #131593
by Type_Zero_Design
Awesome, Thanks Mutt!
Running into this issue though..
Debootstrap error: failed to determine the codename for release
Any ideas?
Any ideas?
Last edit: 23 Apr 2019 02:43 by Type_Zero_Design.
- InMyDarkestHour
- User is blocked
23 Apr 2019 04:09 #131597
by InMyDarkestHour
Usually that's no internet connection
- Type_Zero_Design
23 Apr 2019 05:47 #131601
by Type_Zero_Design
Didn't realize a internet connection was necessary. I'll give that a try.
23 Apr 2019 06:43 #131604
by pl7i92
Replied by pl7i92 on topic Installing LAN on new Linux CNC install
can someone please make a NOTE to the Download README
it needs WWW connection during install
- InMyDarkestHour
- User is blocked
23 Apr 2019 07:08 - 23 Apr 2019 07:17 #131608
by InMyDarkestHour
It's been mentioned quite a few times, many times, in the forum.........Maybe the search button should be HUGE AND RED
Just out of curiosity what method\utility did you use to put the image onto the USB stick ?
Last edit: 23 Apr 2019 07:17 by InMyDarkestHour.
Time to create page: 0.151 seconds
