new install, now cant import tkinter
03 May 2020 18:38 #166522
by owhite
new install, now cant import tkinter was created by owhite
Folks,
I followed this tutorial and it worked fine with mint 19:
gnipsel.com/linuxcnc/uspace/linuxmint19-emc.html
when i installed that, I used build 2.7, it worked fine. I get this from -v
LINUXCNC - 2.7.15
Then when I wanted to install the master, 2.9pre, and I encountered a problem.
There were residual .deb files in my home area, so I removed all those. Then I ran all commands on the mint 19 install page up to:
$ debuild -uc -us
and installed the .deb files, now I'm getting this from
so that looked like good news but when I run linuxcnc and try to start any of the sims I get:
any thoughts?
LINUXCNC - 2.7.15
$ debuild -uc -us
$ linuxcnc -v
Verbose mode on
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/owhite/linuxcnc/configs/sim.axis'
Machine configuration file is 'axis.ini'
File "/usr/bin/update_ini", line 11, in <module>
from tkinter import *
ImportError: No module named tkinter
update script failed in an unexpected way.
LinuxCNC terminated with an error. You can find more information in the log:
/home/owhite/linuxcnc_debug.txt
and
/home/owhite/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
any thoughts?
- Thank you received: 5961
03 May 2020 18:53 #166524
Replied by tommylight on topic new install, now cant import tkinter
Download the ready made ISO from here:
forum.linuxcnc.org/9-installing-linuxcnc...onic-beaver-mint-iso
Or install Linuxcnc on Linux Mint;
forum.linuxcnc.org/9-installing-linuxcnc...-installation#137159
03 May 2020 19:18 #166525
by owhite
Replied by owhite on topic new install, now cant import tkinter
Method 1 from here did not fix:
I'll try the iso.
I'll try the iso.
03 May 2020 19:20 #166526
It was not meant to fix it, it is a much easier way to install on Mint.
03 May 2020 19:48 - 03 May 2020 20:29 #166529
by owhite
Okay. So would you ideas have for dealing with the error?
and
Last edit: 03 May 2020 20:29 by owhite.
03 May 2020 19:52 #166531
Nothing, never seen it before.
Now twice in 2 days!
04 May 2020 00:58 #166558
by phillc54
Replied by phillc54 on topic new install, now cant import tkinter
Could be something to do with the Python3 work being done on master, I would stick with 2.8 at this stage unless there is something specific you need from master.
- BeagleBrainz
- User is blocked
- Thank you received: 570
04 May 2020 02:34 #166563
by BeagleBrainz
Replied by BeagleBrainz on topic new install, now cant import tkinter
Try
sudo apt-get install python3-tk
04 May 2020 07:15 #166585
by bbsr_5a
Replied by bbsr_5a on topic new install, now cant import tkinter
someone shoudt update the install process on UPDATE to Master
to get the python3-tk ito depencies needed
04 May 2020 08:14 #166592
To be fair Python3, is stilla work in progress for LInuxcnc and a lot of PR's were pushed to master bracnh over the last few days.... It would be best to log an issue in git hub.
Replied by rodw on topic new install, now cant import tkinter
Time to create page: 0.136 seconds
