Linuxcnc Mint 19.3 ISO
- BeagleBrainz
- Visitor
26 Apr 2020 03:13 - 25 Nov 2020 00:30 #165631
by BeagleBrainz
Linuxcnc Mint 19.3 ISO was created by BeagleBrainz
First off apologies to all concerned, I have not been myself.
Due to some issues I have had to go walkabout (as far as one can these days) and take a step back from things, therefore I am not hosting the Mint ISO any longer, as I can't supply the support required nor updates either to the image nor packages.
If anyone has an image and can either host or share the image that would be great.
For those that wish to use Mint & Linuxcnc, Tommy has some excellent information & JT has some great tutorials over at gnipsel.com/linuxcnc/uspace/index.html.
Basically any info for Mint 19 will work for 19.1, 19.2 & 19.3.
There have been reports the Buster ISO will install to the Odroid, but NIC drivers will still require manual installation as per the Odroid wiki. The Odroid forum is a good resource for any issues with the Odroid board itself.
Once again apologies to all.
Linuxcnc repository is now available for Uspace aka RT_PREEMPT. No RTAI packages nor images are available at this time.
64 Bit only ie: amd64 no i386 nor i686
The plan is to update the Linuxcnc packages on a Saturday night or Sunday Australian\Sydney time
Setting up the repository is as follows
Import the key:
old key was 60DE9F5F42214E43
Use NEW key below
Some idiot forgot their gpg password
ATM there is an UEFI installation issue..working on that and will have a replacement soon
Add the source:
Finally update the package lists:
To install on a Mint 19.x: installation without Linuxcnc
Optionally:
linuxcnc-doc-en can be replaced by linuxcnc-doc-es linuxcnc-doc-fr
For those that wish to install from a Live image pre installed with Linuxcnc:
ISO:
cnc.beaglebrainz.net/cdimage/cnc-19.2.0-...ate-uspace-64bit.iso
md5:
cnc.beaglebrainz.net/cdimage/cnc-19.2.0-...ate-uspace-64bit.md5
For Mint 19.3 with updated kernel & Official V2.8.0 Linuxcnc:
ISO:
cnc.beaglebrainz.net/cdimage/cnc-19.3.0-...lus-uspace-64bit.iso
md5:
cnc.beaglebrainz.net/cdimage/cnc-19.3.0-...lus-uspace-64bit.md5
All packages were upgraded during creation of the image.
No extras for qtvcp have been installed.
No scripts to download dependencies for building Linuxcnc have been included.
I've attempted to make this as plain as possible.
Included on the ISO in addition to the standard Mint packages are:
Midnight Commander aka mc
Geany
GParted
All Package: glade3
All Version: 3.8.6-1
All Package: hostmot2-firmware-all
All Version: 0.8.21.g5be856c
All Package: mesaflash
All Version: 3.3.0~pre0+dfsg-0
Mint 19.2
Package: linux-headers-4.19.106-rt44-lcnc
Version: 4.19.106-rt44-lcnc-1
Package: linux-image-4.19.106-rt44-lcnc
Package: linuxcnc-doc-en
Version: 1:2.8.0~pre1.5821.g7525a152
Package: linuxcnc-uspace
Package: linuxcnc-uspace-dev
Mint 19.3
Realtek 8125B drivers for Odroid H2+ added
UEFI Installation fixed
Image is suitable for:
PC Legacy boot installation
PC UEFI boot installation
Odorid H2+ (this board supports UEFI boot only)
Package: linux-headers-4.19.106-rt46-lcnc
Version: 4.19.106-rt46-lcnc-1
Package: linux-image-4.19.106-rt46-lcnc
Version: 1:2.8.0
Version: 1:2.8.0
Version: 1:2.8.0
Import the key:
Use NEW key below
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys C9F836336AAD909E ATM there is an UEFI installation issue..working on that and will have a replacement soon
Add the source:
sudo add-apt-repository 'deb http://cnc.beaglebrainz.net/mintcnc/ bionic 2.8-rtpreempt'Finally update the package lists:
sudo apt-get updateTo install on a Mint 19.x: installation without Linuxcnc
sudo apt-get install linux-image-4.19.106-rt44-lcnc linux-headers-4.19.106-rt44-lcnc
sudo apt-get install linuxcnc-uspace linuxcnc-uspace-dev linuxcnc-doc-en
sudo apt-get install mesaflash hostmot2-firmware-allOptionally:
ISO:
md5:
ISO:
md5:
Geany
GParted
All Package: glade3
Mint 19.2
Mint 19.3
Version: 1:2.8.0
Version: 1:2.8.0
Version: 1:2.8.0
Last edit: 25 Nov 2020 00:30 by BeagleBrainz. Reason: Link to new ISO for x86 & Odroid
- Thank you received: 7509
26 Apr 2020 08:43 #165664
Replied by tommylight on topic Linuxcnc Mint 19.3 ISO
Nice work, thank you.
- BeagleBrainz
- Visitor
28 Apr 2020 01:10 #165909
by BeagleBrainz
Replied by BeagleBrainz on topic Linuxcnc Mint 19.3 ISO
For those of you who want to build your own RIP installation or packages:
After setting up the repo & importing the key in the first post
Grab a coffee\tea\keg of beer and take a break for a bit. After this has finished every thing is ready to clone the Linuxcnc sources, checkout the version you want and build (RIP is best before making packages and doing a full install).
sudo apt-get update
sudo apt-get install -y devscripts equivs build-essential --no-install-recommends
sudo apt-get install -y linuxcnc-build-deps --no-install-recommends --no-install-suggests Grab a coffee\tea\keg of beer and take a break for a bit. After this has finished every thing is ready to clone the Linuxcnc sources, checkout the version you want and build (RIP is best before making packages and doing a full install).
- AndrejsA
28 Apr 2020 08:08 #165975
by AndrejsA
Replied by AndrejsA on topic Linuxcnc Mint 19.3 ISO
Firstly, thanks. So far I've tested it only on virtual machine, but I had less issues with it than with wheezy.
I've opted for ISO and RIP installation since I need 2.9 linuxcnc. But I'm having some python2 and python3 related issues.
So what I'm doing, I'm loading linuxcnc with 3axis-tutorial.ini config file, trying to learn about vismach.
but it always crashes on import tkinter. First it was update-ini file, I went in and manually changed to:
"from Tkinter import *
import tkMessageBox" and then went and changed in code few places, so update-ini worked, but then vismach.py crashed also because of tkinter import.
I was thinking to purge python2.7 so that it uses python3, but decided to ask if it makes any sense. Or shall I just rewrite all the files refering to tkinter to use Tkinter instead?
28 Apr 2020 08:14 #165977
You do not need run in place to use 2.9, it is ready on the buildbot site
buildbot.linuxcnc.org/dists/
- AndrejsA
28 Apr 2020 08:20 - 28 Apr 2020 08:23 #165979
by AndrejsA
Is it with Mesa 7I95 support? I did not specify it before, but i need RIP to be able to patch it for 7I95 support
Last edit: 28 Apr 2020 08:23 by AndrejsA.
28 Apr 2020 08:57 #165980
Did not know you needed it for 7i95.
I am not sure it is there, so you do need RIP just to be sure.Is it with Mesa 7I95 support? I did not specify it before, but i need RIP to be able to patch it for 7I95 support
28 Apr 2020 09:00 #165981
Just did a quick check on Mesanet.com, that is a nice board, now i need one to play with!Is it with Mesa 7I95 support? I did not specify it before, but i need RIP to be able to patch it for 7I95 support
- AndrejsA
28 Apr 2020 10:19 #165986
by AndrejsA
My work around for now was just to add some if: else: statements to load the correct tkinter libraries and it lead to creating a tk window with vismach config. For now it works, till I figure out how to get rid of python2 and use only python3
My bad, I forgot to mention it.I am not sure it is there, so you do need RIP just to be sure.
- BeagleBrainz
- Visitor
28 Apr 2020 12:12 #165996
by BeagleBrainz
I thought Linuxcnc still relied on python 2.7 and going to 3.0 needed some reworking due to the differences.
Time to create page: 0.120 seconds
