Linuxcnc Mint 19.3 ISO
17 May 2020 11:17 #168040 by tommylight
Replied by tommylight on topic Linuxcnc Mint 19.3 ISO
Did by any chance the monitor get detached prior to such issues ?
Mint with Mate has a habit of leaving stuff on the desktop or not showing them after messing with the monitors like detaching them and attaching them to the same or another port, same thing on the laptops when switching monitors.
Usually it goes away after a short while, but sometimes only reboot helps.
17 May 2020 14:35 #168065 by Clive S
Replied by Clive S on topic Linuxcnc Mint 19.3 ISO
No. Its been ok all day today :) Just playing about with setting up a PP with 2 ports for PlasmaC
17 May 2020 14:43 #168067 by tommylight
PP as parallel port, or post processor or path pilot ? :)
17 May 2020 14:52 #168070 by Clive S
Don't take the P out of a pensioner. You wouldn't have 2 ports with a post processor . So yes as a parallel port
27 Jul 2020 11:43 - 27 Jul 2020 11:44 #176067 by Clive S
Did you install it and attempt to update the Linuxcnc packages ?
Yes I ran sudo apt-get update sudo apt-get dist-upgrade.
I have just run the above again and it ran fine.
Cheers clive much appreciated.
Rob: First a big thank you for the iso I have used it many times.
I am not sure if your server is down but I am seeing that it is not updating. It is showing PlasmaC as version 0.126 and it should be around V0.145
I know you said you generally update on a weekend but thought I would check in to see if it was my problem here.
Last edit: 27 Jul 2020 11:44 by Clive S.
  • BeagleBrainz
  • BeagleBrainz's Avatar Topic Author
  • Visitor
  • Visitor
27 Jul 2020 22:33 #176156 by BeagleBrainz
Replied by BeagleBrainz on topic Linuxcnc Mint 19.3 ISO
Updates coming soon, I've been knee deep in other stuff, apologies to all.
  • BeagleBrainz
  • Visitor
  • Visitor
04 Aug 2020 11:25 #177216 by BeagleBrainz
New keys for update, run this command
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys C9F836336AAD909E
04 Aug 2020 12:43 #177232 by Clive S
That cured it many thanks Rob
07 Sep 2020 08:04 #181105 by JackRay
Replied by JackRay on topic Linuxcnc Mint 19.3 ISO
Hello, BeagleBrainz.
I logged into the forum a very short time ago. I am in the process of refitting my 5 axis CNC machine with linuxCNC 2.8. I start with a totally virgin PC, and the ideal solution to configure it with LinuxMint + Linuxcnc integrated.
So I used your .iso image for the installation which is a fantastic job. I meet a Problem at the installation. An error message that mentions that the package. I have redone the installation several times, but impossible to go further.
Can you please help me.
thank you so much
  • BeagleBrainz
  • Visitor
  • Visitor
07 Sep 2020 09:47 #181111 by BeagleBrainz
Unfortunately my French is absent.
All I can make out is there is an issue installing grub.
As the installer is exactly as shipped by Mint some further searching regarding the issue maybe required on your behalf.
Time to create page: 0.534 seconds
